Wire harness compatibility question
  • chris_heiges
  • chris_heiges's Avatar Topic Author
20 May 2023 08:37
#884963
So I’ve got this kz1000p it’s a 2000.
came to me as a skeleton so I’m using it as a canvas for an art project I’ve had in mind for a while, I plan to add the dyna s ignition to it, and strip it down to just a headlight and tail light. I’d like to get a new wire harness for it and then strip the harness to bare bones. The only one I have found so far is for a kz1000a for 77-78
Would this be a good harness to start with to make this work? I’m assuming it should be similar?
Gloucester Va
2000 KZP
2007 Harley Fatglide
  • TexasKZ
  • TexasKZ's Avatar
Re: Wire harness compatibility question
20 May 2023 11:49 - 20 May 2023 11:53
#884974
It would be less work to make your own harness from scratch.
Somewhere in this long thread you may be able to find a bare bones system for the later KZ1000.
kzrider.com/forum/4-electrical/172746-19...r-mattylight?start=0
Last edit: 20 May 2023 11:53 by TexasKZ.
The following user(s) said Thank You: chris_heiges
