1976 Kawasaki KZ 400 without battery
- kdx200
26 Apr 2023 10:21
Can A 1976 Kawasaki KZ 400 be started(kicked) and RUN without a battery?
Re: 1976 Kawasaki KZ 400 without battery
26 Apr 2023 13:21
No, the generator won't produce enough power at "kicking" speed to power the ignition
- gordone
04 May 2023 14:24
Could installing condensator be a option?
Project:
Project:
04 May 2023 17:42
A large capacitor might work, but a modern regulator and a LiFePo battery might be a better choice.
- Nerdy
04 May 2023 19:00
In theory I think that could work, but large capacitors can be dangerous. Back in the days of CRT-based televisions, people would get knocked on their backsides (or worse) by the capacitors inside the TV.
I think an ignition - even for a small bike - would need a noticeably larger capacitor than would be found in a TV, making the idea more risky.
Also I think the bike would basically need to start on the first kick every time for the concept to work. I'm not a double-e and might very well be wrong on the math. TexasKZ's idea is probably the way to go.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
04 May 2023 23:25 - 05 May 2023 00:35The stock generator is "regulated" by battery voltage (no battery means no regulation) so you would need a totally different generator set up (like a motocross bike or lawnmower) or you will fry the generator. Why do you want to run without a battery ? Also I believe the KZ400 has a "field coil" generator which requires a battery feed to the field coil to generate anythingCould installing condensator be a option?
Last edit: 05 May 2023 00:35 by Wookie58.
