TEC MP08 coil
- oldblighty
TEC MP08 coil
11 Apr 2023 12:37
Does anyone know if a Tec mp08 coil would fry a a kz440 TCI box
Re: TEC MP08 coil
11 Apr 2023 12:57
Brand is irrelevant, the current drawn by the coil is determined by the primary winding resistance so as long as the new coil resistance is within manufacturer spec (ref manual) you should be fine
- oldblighty
Re: TEC MP08 coil
11 Apr 2023 14:00 - 11 Apr 2023 14:11
Thanks just can’t find coil ohms spec for a 440 tci ignition, mp08 coil primary reads 2.7 ohms
Last edit: 11 Apr 2023 14:11 by oldblighty.
Re: TEC MP08 coil
11 Apr 2023 14:12It's the resistance of the ignition coil primary winding you are looking for, not the TCI unitThanks just can’t find coil ohms spec for a 440 tci ignition
- oldblighty
Re: TEC MP08 coil
11 Apr 2023 15:26
Then would the 440 use same coil primary resistance for both the points system and the tci system this is what I can’t seem to find in the manual
Re: TEC MP08 coil
11 Apr 2023 16:07
Manual page 276 states 1.8-2.8 ohms
The following user(s) said Thank You: oldblighty, Wookie58
Re: TEC MP08 coil
11 Apr 2023 23:24
From what I can see the MP08 coils are 2.7 ohms so should be fine (check with a meter before fitting)
- oldblighty
