80 KZ 1000-B4 LTD Frame Ground
  • Jasongpz
  • Jasongpz's Avatar Topic Author
03 Apr 2023 14:57
#882433
I've obtained a 1980 KZ 1000-B4 LTD with the wiring harness in the box.  I've got 95% of the wires identified, labeled, and hooked up.  All I need now is to identify where the negative battery cable is grounded to the frame.  Can anyone help?  Pictures would be great.
1985 GPZ 750 ZX750-A3
1980 KZ 1000-B4
  • Warren3200gt
  • Warren3200gt's Avatar
Re: 80 KZ 1000-B4 LTD Frame Ground
03 Apr 2023 15:08 - 03 Apr 2023 15:15
#882435
The large earth strap from the battery negative earth's to the engine not the frame.
Normally there's a specific bolt hole for it above where the kick-start is (if your bike had one, not 100% re your model)
Last edit: 03 Apr 2023 15:15 by Warren3200gt.
The following user(s) said Thank You: Jasongpz
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Apr 2023 15:20
#882436
There is a M6 screw hole next to the rear upper engine mount on the RH side next to the kick-start.
The following user(s) said Thank You: Mikaw, Jasongpz
  • hardrockminer
  • hardrockminer's Avatar
03 Apr 2023 17:59
#882447
As Warren says, the ground strap from the battery negative is bolted onto the side of the engine, in behind the kick starter.  The hole takes a 6M by 14mm hex bolt.  If you want to be absolutely correct the bolt has a #4 on it.
The following user(s) said Thank You: Warren3200gt
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
03 Apr 2023 18:17
#882449
You can see the battery ground wire bolted to the engine case just below the motor mount. Never mind that it is a Honda bolt, it had a battery terminal bolt there when I got the bike. Every non-Honda bike we've resurrected has at least one Honda bolt on it somewhere.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • hardrockminer
04 Apr 2023 10:18
#882489
My Goldwing is covered with Allen button head screws.  It seems they are all different lengths, and several diameters.  My guess is that no one told the engineers that standardized screw length and dia were worth the effort.
  • Jasongpz
05 Apr 2023 06:27
#882533
Thanks all for the help!
1980 KZ 1000-B4
