Igniter box power transistor
- ckahleer
23 Jan 2023 18:43
Can someone identify this transistor and have a source where I could order a couple. I'm going to try to repair an igniter box.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
Re: Igniter box power transistor
23 Jan 2023 19:39
I see them on ebay....shipping from China. 2SD1071 is the number.
24 Jan 2023 06:29 - 24 Jan 2023 06:41
For future reference. What igniter & motorcycle is it? Thanks.
In case it's any help. Here's a link w some info for a Yamaha but he didn't actually do or complete the repair.
www.jetav8r.com/Vision/TCIRebuild/TCI_Rebuild.pdf
Last edit: 24 Jan 2023 06:41 by martin_csr.
- ckahleer
24 Jan 2023 06:46
Its an igniter off an 85 VT500c.
I found 1 US supplier, Newegg. They want $45.99 for 2.
Soon we will need a wheelborrow of money for a loaf of bread.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- OKC_Kent
24 Jan 2023 10:44
Check on Amazon. I'm a buyer at my company and just purchased these for a little IT project. 11 bucks for 1,000 various transistors. You should be able to find what you need there, but how good the quality is will not be known. All China stuff these days.
BOJACK 1000 Pcs 25 Values Resistor Kit 1 Ohm-1M Ohm with 5% 1/4W Carbon Film Resistors Assortment: Amazon.com: Industrial & Scientific
Cashion, OK
78 KZ650 B2 85,000+ miles
- Nerdy
24 Jan 2023 13:15
Try Mouser or Digi-Key for individual components:
www.mouser.com/
www.digikey.com/
Amazon (or eBay) will almost certainly be the cheapest; the other places can be pricey for small quantities.
Or there is an igniter for an '83 VT500 on eBay for about $48 shipped: https://www.[ebay].com/itm/334290106376
www.mouser.com/
www.digikey.com/
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
24 Jan 2023 13:24Try Mouser or Digi-Key for individual components:
www.mouser.com/
www.digikey.com/
I already checked Mouser and Digikey. They don't have it.
eBay is the only place I could find this particular component.
Searching the web shows that Yamaha Vision also uses this component in it's ignitor box. It's a small world with usage of these particular parts.
24 Jan 2023 14:23 - 24 Jan 2023 14:27
https://www.[ebay].de/itm/381661365284 10 transistors 2SD1071 / D1071 FUJI for US $5,09
Last edit: 24 Jan 2023 14:27 by Scirocco.
- ckahleer
24 Jan 2023 18:41It would have to be an 85 or 86 box. Unfortunatly, they are few and pricey. The pre 85s used a seperate igniter box for each cylinder.Or there is an igniter for an '83 VT500 on eBay for about $48 shipped: https://www.[ebay].com/itm/334290106376
I may just order the transistors from China and hope for the best.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
25 Jan 2023 07:34 - 25 Jan 2023 07:52
Here's a topic from the Digi-Key Tech forums. Finding a replacement transistor (2SD1071) for a 90s motorcycle igniter:
forum.digikey.com/t/finding-a-replacement-transistor/26008
Two alternate part numbers mentioned: MJE5742G or BU941.
MJE5742G doesn't have a zener diode, so you'd need to install that separately.
Also, on a Gixxer forum one guy just replaced the capacitors & cleaned up or resoldered some of the connections and removed some of the melted gunk which can be conductive. And that guy or another gixxer guy replaced some of the resistors w brass rod. If interested, I saved the links.
Last edit: 25 Jan 2023 07:52 by martin_csr.
The following user(s) said Thank You: F64
