1979 Kawasaki Z1000 MK2 A3A electrical issues
  • policebikes
  • policebikes's Avatar Topic Author
10 Dec 2022 17:42 - 11 Dec 2022 05:35
#877705
Gents, and ladies if any frequent this forum, I'm stumped!
As noted in a previous post, I have all the idiot lights working, headlight, indicators and brake lights work, but I still can't get the horn, passing beam, or go button to work.
All wires are connected, except a black one from the left handlebar control which doesn't seem to have a home that I can find.
I'm using the A3 European spec wiring diagramme as shown in the photo, but can't seem to find out where I'm going wrong.
For context, the OEM wiring harness and handlebar controls are installed, the battery is both new and fully charged.
Any thoughts, hive mind?
Last edit: 11 Dec 2022 05:35 by Street Fighter LTD.
  • Mikaw
  • Mikaw's Avatar
Re: 1979 Kawasaki Z1000 MK2 A3A electrical issues
11 Dec 2022 15:06
#877722
Are they OEM controls of emgo?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Dec 2022 18:19
#877726
Missing ground to the controls and handle bar?
  • F64
  • F64's Avatar
  • 81-KZ440D2
11 Dec 2022 19:19
#877727
Go button?
Do you have a meter?
81-KZ440-D2.
LIC, NY
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
11 Dec 2022 20:19
#877728
Not sure about go button either?  Will say the horn button is the ground source for the horn. I would also ask what sort of end/connector is on the end of the black lead that appears to have nowhere to go?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • TexasKZ
  • TexasKZ's Avatar
12 Dec 2022 05:21
#877734
By go button, I suspect he means the starter button.
If so, then a lack of ground through he bar seems likely. If the handlebar has recently been painted or is an aftermarket bar, then the switchgear may not be getting a proper ground connection through the bar as intended.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
12 Dec 2022 05:50 - 12 Dec 2022 06:27
#877736
The only black wires from the left handlebar control are the two from the clutch switch. one should go to the black from the right handlebar switch and the other to the starter solenoid. If either is disconnected, then the "Go" button isn't going to work. The horn fault is the only "ground" relevant fault ref handlebar switch. Check voltages ref the below
Last edit: 12 Dec 2022 06:27 by Wookie58.
  • policebikes
12 Dec 2022 22:05
#877756
OEM
