Points and Ignition Timing - $425
- ShaneDude
- Banned
14 Sep 2022 09:27
Who here has changed their own points and all thats involved in it, including timing? A local shop said, for me to have the points changed on my 77 K750 TWIN, it would be $425. Im thinking thats kind of ridiculous?
Re: Points and Ignition Timing - $425
14 Sep 2022 09:40
That sounds like a "we don't want the job" price !! take your time and follow the manual and you should be fine
- ShaneDude
- Banned
14 Sep 2022 12:36
It really is pretty straightforward, just make sure the washers and insulators on the mounting screws go back in the right order. You can set the gap with feeler gauges if you don't have a dwell meter and set the static timing with a testlight or voltmeter.
- ckahleer
14 Sep 2022 13:12 - 14 Sep 2022 13:12
Setting dwell and timing is not difficult. If you were near me, I would do it and teach you how, for $100 and a case of beer. What is your location. Maybe someone near you will even under bid me.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Last edit: 14 Sep 2022 13:12 by ckahleer. Reason: spelling
- ShaneDude
- Banned
14 Sep 2022 15:37
im pretty sure youre not close to me. ive decided to go with a shop that is charging me $250. I dont want to mess this up
14 Sep 2022 15:45
15 Sep 2022 04:27
Nothing wrong with points and condensers but if you are ready to change them....consider a Dyna pickup.
15 Sep 2022 06:28
Do the Dyna once and you're done for the life of the bike
So cost payback is great compared to periodic point adjustment or replacement by a shop
DD
DD
- ShaneDude
- Banned
15 Sep 2022 07:20
never heard of dyna for these bikes. what components would I need? is it pricey?
- ShaneDude
- Banned
15 Sep 2022 07:24Nothing wrong with points and condensers but if you are ready to change them....consider a Dyna pickup.
Do I have to have a dyna coil as well?
15 Sep 2022 09:01
You can use the standard coil as long as the resistance is approx 3 - 4 ohms which I believe it is
