Points and Ignition Timing - $425
  • ShaneDude
  • ShaneDude's Avatar Topic Author
  • Banned
  • Banned
14 Sep 2022 09:27
#873880
Who here has changed their own points and all thats involved in it, including timing? A local shop said, for me to have the points changed on my 77 K750 TWIN, it would be $425. Im thinking thats kind of ridiculous?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Points and Ignition Timing - $425
14 Sep 2022 09:40
#873881
That sounds like a "we don't want the job" price !! take your time and follow the manual and you should be fine
  • ShaneDude
  • Banned
  • Banned
14 Sep 2022 10:07
#873883
THANKS!
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Sep 2022 12:36
#873886
It really is pretty straightforward, just make sure the washers and insulators on the mounting screws go back in the right order. You can set the gap with feeler gauges if you don't have a dwell meter and set the static timing with a testlight or voltmeter.
  • ckahleer
  • ckahleer's Avatar
14 Sep 2022 13:12 - 14 Sep 2022 13:12
#873887
Setting dwell and timing is not difficult. If you were near me, I would do it and teach you how, for $100 and a case of beer. What is your location. Maybe someone near you will even under bid me.
97 ZL600
94 VF750c
94 KE100
82 KZ305
Last edit: 14 Sep 2022 13:12 by ckahleer. Reason: spelling
  • ShaneDude
  • Banned
  • Banned
14 Sep 2022 15:37
#873894
im pretty sure youre not close to me. ive decided to go with a shop that is charging me $250. I dont want to mess this up
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Sep 2022 15:45
#873896
Discretion is sometimes the better part of valour if you are not totally confident
  • hardrockminer
  • hardrockminer's Avatar
15 Sep 2022 04:27
#873910
Nothing wrong with points and condensers but if you are ready to change them....consider a Dyna pickup.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
15 Sep 2022 06:28
#873915
Do the Dyna once and you're done for the life of the bike
So cost payback is great compared to periodic  point adjustment or replacement by a shop
DD
  • ShaneDude
  • Banned
  • Banned
15 Sep 2022 07:20
#873916
never heard of dyna for these bikes. what components would I need? is it pricey?
  • ShaneDude
  • Banned
  • Banned
15 Sep 2022 07:24
#873917
Do I have to have a dyna coil as well?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
15 Sep 2022 09:01
#873925
You can use the standard coil as long as the resistance is approx 3 - 4 ohms which I believe it is
