Coils
- Pattenrd
Coils
11 Sep 2022 15:40
Out for a ride my z1 900 today after about 45 minutes bike lost power felt like it dropped 2 cylinders let sit for 10 minutes started ran good possible bad could or points problem should I upgrade ignition
Re: Coils
11 Sep 2022 16:06
Are you running original coils? If so, they should measure about 3.8 ohms on the primary side and about 13,000 ohms from plug wire to plug wire.
Most Z1 riders upgraded to a Dyna S2 system. That would be the green Dyna coils and the recommended pickup for a Z1. Just guessing at the cost, but around $250.
The following user(s) said Thank You: Pattenrd
- TheTrout
Re: Coils
12 Sep 2022 07:12
Go with a new dyna ignition and green coils and never need to adjust points again. It was one of the best upgrades I did to my bike (many years ago).
1978 KZ1000B2
