Low or no voltage from stator
- littlebigcj
10 Sep 2022 01:09
Hi
Struggling to charge my battery at the moment. Bike dies after 20 mins of riding. I’m using a ricks reg rec on my 74 KZ400 with a lithium battery. The exciter coil is getting 12v and ground through the two wires.
The three stator wires are getting sometimes mvs or 12v each. But always the same. They all get 0.9-1ohm resistance between A-B,B-C,A-C. Although these are higher than spec, the fact that they are all identical and no ground makes me think it’s working as intended.
My theory is that the exciter field coils cable has become damaged behind the clutch cable cover. What should the resistance be on the exciter field cables? Any other ideas?
Thanks.
Thanks.
Re: Low or no voltage from stator
10 Sep 2022 14:33 - 10 Sep 2022 14:51
With the green and black wires disconnected from the RR check resistance between the green wire and the engine casing. The output on the three yellow wires should be significantly more than 12v, I have to say that I don't believe a lithium battery is compatible with this (dynamo) type chargeing system as the output is too irratic and Lithium requires a stable charging voltage
EDIT: I am assuming the engine is running when you have 12v on the three yellow output wires ?
Has this set up been working previously and if so what was the system voltage when running?
Last edit: 10 Sep 2022 14:51 by Wookie58.
- littlebigcj
10 Sep 2022 15:17
Hi
Thanks for your reply. Yep the 12v output from the stator was when the engine was running. It has previously ran well before I rebuilt with a new battery and reg rec. So I assume the stator and exciter coil still works as expected.
Ricks reg Recs are high quality and state they work with kz400s and lithium batteries.
What resistance from the exciter coils should I expect?
Cheers
Cheers
10 Sep 2022 15:55 - 10 Sep 2022 16:05
I am not sure on field coil resistance specs, did you check resistance between the green field wire and the engine casing with the black field wire disconnected ?
Am I understanding correctly that the bike has not run correctly with this RR/ Battery combination ?
Did Ricks provide you with conversion wiring from the separate regulator and rectifier, if not how have you wired it ?
Last edit: 10 Sep 2022 16:05 by Wookie58.
- F64
- 81-KZ440D2
10 Sep 2022 17:05
Did you measure your stator wires on the AC voltage setting on your meter?
81-KZ440-D2.
LIC, NY
LIC, NY
- littlebigcj
11 Sep 2022 14:13
Hello
Yes set to AC. Getting 5ohm resistance on the exciter coil which sounds feasible. My next idea is to put a 12v bench top power supply to the exciter coil and then measure the stator AC voltage.
Very high resistance between both green and black wires to ground. So as expected.
It’s a complete re wire of the entire bike using ricks reg/rec with a motogadget m unit blue.
Using this one.
Using this one.
11 Sep 2022 15:11You say there is a resistance measurement between the green and black to ground. - what is the reading - is this with the green and black disconnected from the RR if so the field coil is faulty as .,there should be no circuit to earth also I would recommend a 30a fuse in the RR output back to the battery. When using a lithium battery with an old charging system there is a risk of a generator fault causing a "thermal runaway" (battery fire) which is almost impossible to extinguish !!!!Hello
Using this one.
- littlebigcj
13 Sep 2022 05:32
The resistance was very high, like mega ohms between the exciter coil inputs. Just tried it again, I was getting like 25v AC at 4000 rpms and the input to the battery was over 13v. Is this normal?
Yes, the battery is fused with 35A fuse.
13 Sep 2022 06:37As long as the RR output to the battery is around 13.5v - 14.5v (and it is higher than the static battery voltage when the engine is off ) then you are all good and it is chargingThe resistance was very high, like mega ohms between the exciter coil inputs. Just tried it again, I was getting like 25v AC at 4000 rpms and the input to the battery was over 13v. Is this normal?
Good to hear you are fused (better safe than BBQ'd)
- blipco
- 2002 KZ1000P
13 Sep 2022 07:18
My brother just installed a Ricks R/R in his KZP. We measured the output from the stator at around 50vac. The charging voltage with the battery connected at 4000rpm and various rpm was a steady 13.7vdc. I was expecting mid 14 volts.
13 Sep 2022 07:37The bike in question is a 74 400 with dynamo type (separate field winding) generator so the readings will be lower (I assume the KZP had a combined RR from factory) RR's that are intended for lithium batteries aim for as constant an output as possible, small fluctuations in voltage ideally within a couple of points either way of 14v (13.8 - 14.2v)My brother just installed a Ricks R/R in his KZP. We measured the output from the stator at around 50vac. The charging voltage with the battery connected at 4000rpm and various rpm was a steady 13.7vdc. I was expecting mid 14 volts.
- blipco
- 2002 KZ1000P
13 Sep 2022 07:53Wookie58 post=873823
My bad, not paying attention.
