Ingition pistol rpm reading weird
  • KZ650B_Joerg
  • KZ650B_Joerg's Avatar Topic Author
09 Sep 2022 04:23
#873593
Hello,
I have a strobo light with a rev counter in. Putting it to 2-stroke mode, it should read correct rpm (one spark each rev).
What I see is fluctuate reading between right and double the revs compared to what the bikes tachometer shows.
It changes erratic, on 1-4 it is from 2 times a second to "double spikes". On 2-3 its mostly double with spikes to the right rpm.
Is it a false reading of the strobo tool (e.g. sensor at the plug gets neighbors signal too) or false spark? How can I narrow it further down?
The Z650B is quite new to me. Points and ignition timing are adjusted to spec and looking well.
Cheers
Joerg
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Ingition pistol rpm reading weird
09 Sep 2022 04:58
#873594
Don't forget when you use a strobe light on a car with a distributor each lead only sparks every 720 degree's (camshaft turns at half engine speed) with a bike with dual output coils and a "lost spark" set up each lead sparks every 360 degrees (so double) depending on the strobe you have I'm not sure you will get an accurate tacho reading (does it have an option for 8 cylinders (twice as many sparks as a four cylinder in car world)
  • KZ650B_Joerg
09 Sep 2022 06:21
#873596
Hi,
I thought the 2-stroke setting would do it. One revolution - one spark per cylinder (combustion or lost) - one rev count.
Cheers
Joerg
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
09 Sep 2022 06:45 - 09 Sep 2022 06:47
#873597
Each cylinder only fires a power stroke every second revolution so it depends what your tacho is looking for
Fire - power stroke - exhaust stroke (one revolution)
          Induction stroke - compression stroke (second revolution)
Last edit: 09 Sep 2022 06:47 by Wookie58.
  • KZ650B_Joerg
09 Sep 2022 07:14
#873598
Ok. Just put 3 + 4 spark plug out, ignition on and turned the crankshaft with the 17 wrench.
It does one spark per revolution on spark 4 and one on 3. So I think I am good with my spark frequency.
Is it normal that the points check bulb does not go out when I pass the F mark (point opens)?
It glows low and stays there until point closes again but isn't out. Cables to coil are connected, ignition is out, kill switch is on.
Repair manuals tell that it should go out.
Cheers
Joerg
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
09 Sep 2022 11:56 - 09 Sep 2022 12:04
#873612
Repair manuals tell that it should go out. It won't go out completely straight away as the condenser is there to soften the switching action so the points don't burn up
Cheers
Joerg
Last edit: 09 Sep 2022 12:04 by Wookie58.
  • KZ650B_Joerg
12 Sep 2022 02:57
#873750
Hi,
I researched a bit on wasted spark concepts and learned that the combustion stroke has a much higher spark voltage compared to the exhaust stroke because of huge pressure differences. 10.000 vs 1000 volts is stated.
So I assume that my RPM meter gets confused and detects the wasted spark sometimes and sometimes not and thus shows double/single  readings. Probably I need a better measuring device to tune my air screws to max rpm.
Cheers
Joerg
  • Warren3200gt
  • Warren3200gt's Avatar
12 Sep 2022 03:13 - 12 Sep 2022 03:49
#873751
Use a gunson colourtune tool to set airscrews not rpm. It's not an expensive tool.
With a colourtune you can get it accurate by actually seeing the mixture burn colour for each cylinder.
Orange burn is rich, blue is lean. At approx 1800 rpm you want to see blue with a merest hint of orange.
Last edit: 12 Sep 2022 03:49 by Warren3200gt.
  • KZ650B_Joerg
12 Sep 2022 04:47
#873754
Yes, will do. I have already purchased the tool.
Cheers
Joerg
The following user(s) said Thank You: Warren3200gt
  • KZ650B_Joerg
12 Sep 2022 08:52 - 12 Sep 2022 08:53
#873760
Following Warrens advise, I did the Colortune exercise today afternoon. It went well.
All four showed orange with some blue spots at idle with airscrew 1.5 out. Added another 8th or so out to get it more into blue.
Took her to a test drive, all fine, great trottle response.
Is there a description on what the test spark should show for my engine/carb at what rpm range? I only checked idle today.
Its a Z650B2 with a VM24SS, all stock.
Thanks to Wookie and Warren helping me out.
Cheers
Joerg
Last edit: 12 Sep 2022 08:53 by KZ650B_Joerg.
The following user(s) said Thank You: Warren3200gt, Wookie58
  • Warren3200gt
12 Sep 2022 09:03 - 12 Sep 2022 09:17
#873762
You can't use colourtune above about 2500 rpm with any safety.
The glass view point could break from rapidly repeated high compression and send shards out at high velocity above that. Dread to think what that could do to an eye if viewing when it broke. Safety first.
Pilot circuit is approx up to 1/3 throttle. Main jet is upto about 2/3's. Needle valve is the last third. There is overlap between each circuit to ensure smooth throttle response.
If you need to check mixture at higher than 2k rpm you need to do it by the plug chop method. If you decide to do this ensure you cut the engine whilst at that rpm and coast to a stop. Then check the plug colour.
Last edit: 12 Sep 2022 09:17 by Warren3200gt.
