81 KZ305 Looking for a better headlight
  • ckahleer
  • ckahleer's Avatar Topic Author
26 Aug 2022 08:28
#872894
The stock headlight puts a spotlight shaped circle of light on the road that is not very bright. I am looking for bright and wide.
High beam seams adequate, but I don't get to use it much. This stock headlight is rated 35w low/ 55w high.
Is there a sealed beam 55w/60w light that will be plug and play with the existing bucket? I could replace the entire headlight assembly if necessary.
I'm a bit skeptical about going LED. Reviews seem to be mixed. Also, I want to keep the stock look of the bike.
1997 ZL600
94 KE100
82 KZ305
74 TC185
  • Moose1800
  • Moose1800's Avatar
Re: 81 KZ305 Looking for a better headlight
26 Aug 2022 09:03 - 26 Aug 2022 09:19
#872895
Here's a good read on lighting.
www.ratwell.com/technical/BoschH4.html
The headlight below is what I had before I had a mishap and broke it, I still cry about that to this day!!!
[img
Last edit: 26 Aug 2022 09:19 by Moose1800.
  • Nerdy
  • Nerdy's Avatar
  • Away
26 Aug 2022 10:59
#872899
You'll be able to filter out a lot of the junk by looking at DOT-approved headlights from reputable (or at least recognizable) brands.
I get the desire to keep the stock look, but the headlight is a big enough safety feature that I want the best practical option. Lighting has made a lot of progress in the past 40+ years; I'll take advantage of that wherever possible.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • JR
  • JR's Avatar
26 Aug 2022 14:47
#872910
Cross referencing from Partzilla it appears that the 305 headlight is also used in a range of 400 s and 440s. Partzilla- kawasaki - year - model - headlight + bits and then "where used" will give you a list. If you can find a sealed beam that fits a 400/440 it should work. Just double check.
i found a Wagner sealed beam much better than stock and a great price but it would not fit a 305.
  • Nebr_Rex
  • Nebr_Rex's Avatar
26 Aug 2022 15:24
#872911
Search CB350 headlight.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • ckahleer
31 Aug 2022 10:06 - 31 Aug 2022 11:54
#873137
No eBay APP ID and/or Cert ID defined in Kunena configurationI found this one on e-bay.
I believe going from 35w to 60w on low beam should help.
1997 ZL600
94 KE100
82 KZ305
74 TC185
Last edit: 31 Aug 2022 11:54 by ckahleer. Reason: link not showing
  • Nerdy
  • Nerdy's Avatar
  • Away
31 Aug 2022 17:38
#873154
Well, the link showed up when I quoted you but in general the non-showing-up-ness of ebay links is a known issue.
You can put square brackets in the URL and it will at least show up, even if it's not an actual link: https://www.[ebay].com/itm/155008426102
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Irish Yobbo
  • Irish Yobbo's Avatar
31 Aug 2022 21:25
#873161
This can be a little dangerous. If the wiring is designed for 35/60W, you're adding a lot more to the 35W circuit than was intended. Chances are nothing will happen and it will be fine, but there always a chance that wires could heat up, melt, or even set on fire. The switches on these are quite simple, there's no relay and all current goes through the switch which can also be a weak point.
I would recommend going for an LED bulb. They don't all look like spiders from the future, and you can get bulbs that just plug into the existing bucket. LEDs draw less current for the same amount of light. LEDs also have a significant advantage on old bikes. Whereas incandescent and halogen bulbs are dependent on voltage, which after 40 years on old wires is likely to have dropped significantly, LED headlights are dependent on current which is controlled internally, so a normal voltage drop won't result in a significant drop in power like you see with incandescent and halogen bulbs.
1981 KZ750 LTD
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
01 Sep 2022 08:13 - 01 Sep 2022 08:15
#873173
My brother bought a round led headlight for his KZP from this company. (He previously had one from Trucklight brand which flickered at low rpm then eventually burned out).
The Dapper led headlight looks like a stock sealed beam but is brighter, doesn’t flicker and throws an excellent pattern. They ain’t cheap and for my brother to say it was worth every penny is testimony more than you know.
www.dapperlighting.com
Last edit: 01 Sep 2022 08:15 by blipco.
  • ckahleer
01 Sep 2022 11:52 - 01 Sep 2022 12:05
#873182
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI went ahead and bought a $40 headlight off e-bay. $300 for that Dapper light is more than I wanted to spend and doesn't look like it will fit in the bucket.
Since the stock light has a 50w high beam, I thinking the wiring and switch for 55/60w will be OK. The wire for high and low beam are the same gage.
WWW.EBAY.COM/ITM/155008426102
1997 ZL600
94 KE100
82 KZ305
74 TC185
Last edit: 01 Sep 2022 12:05 by ckahleer. Reason: Just trying things. manualy typed out link
  • Warren3200gt
  • Warren3200gt's Avatar
02 Sep 2022 11:58
#873234
Motorcycle hi/low Led H4 is all you needed. Plug and play with existing socket / lens / wiring and switches.
  • ckahleer
02 Sep 2022 13:05
#873243
A kz305 does not use an H4 bulb. it is a sealed beam headlight.
The headlight I ordered is one that contains an H4 bulb, so once I get it installed, if I'm still not satified, I will be able to try an LED H4 bulb.
Most H4 LED bulbs have seen have a heat sink. Will they get enough cooling in a headlight bucket?
1997 ZL600
94 KE100
82 KZ305
74 TC185
