KZ750 Twin Regulator/Rectifier relocation
  • ShaneDude
  • ShaneDude's Avatar Topic Author
  • Banned
  • Banned
09 Aug 2022 11:40
#871925
Im about to install a new battery and reg/rec in my 77 KZ750B. Im not happy with the stock position of the reg/rec. There is not a lot of airflow under the massive sidecover.
Any idea on where I might relocate it to?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: KZ750 Twin Regulator/Rectifier relocation
09 Aug 2022 12:34
#871927
I would relocate the reg/rec unit under the battery tray.
  • ShaneDude
  • Banned
  • Banned
09 Aug 2022 12:47
#871929
Im thinking something more like the triumphs which have them up front. near the forks.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Aug 2022 14:13 - 09 Aug 2022 14:18
#871931
Trust me, you don´t need more air flow on your reg/rec like a ram air system for carbs! Do not made any rocket science here!!!
Your alternator power out put is less than a half of a modern bike!
Last edit: 09 Aug 2022 14:18 by Scirocco.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
09 Aug 2022 15:16 - 09 Aug 2022 15:18
#871934
If you are so determined....,,,.and am only mentioned what I did as an idea.  .......I installed a SH775 under the rear fender, but this was a 750-4, not a twin.     I do know where to get,...and how to make,,, 'factory' electrical connectors.         The SH775 was much bigger than stock....and got the idea from a Yamaha FZ-09 which also have it under the fender.
Last edit: 09 Aug 2022 15:18 by hugo.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
09 Aug 2022 15:54
#871937
If your new RR is a MOSFET ( transistorised unit) then they run much cooler than the old diode units and cooling is less of an issue. Just make sure wherever you put it that it is bolted to a heat sink and you should be fine
  • Nessism
  • Nessism's Avatar
  • Away
09 Aug 2022 17:43
#871944
Correct me if I'm wrong, but doesn't the '77 750 Twin use a field coil in it's charging system?  Assuming yes, doesn't it use a special R/R (or separate regulator and rectifier?)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Aug 2022 18:36
#871946
As allways, a picture of the charging system would be very helpful to clarify the charging inviroment.
  • TexasKZ
  • TexasKZ's Avatar
10 Aug 2022 07:02 - 10 Aug 2022 07:04
#871969
The parts diagram at Partzilla shows two charging systems for the 1977 750 B2. I guess a change was made during that model run. If so, identifying which system is on the bike in question seems paramount to resolving the issue.
www.partzilla.com/catalog/kawasaki/motor...erator-starter-motor
One system has a unified RR, while the other uses separate components.
www.partzilla.com/catalog/kawasaki/motor...-regulator-rectifier
Last edit: 10 Aug 2022 07:04 by TexasKZ.
  • ShaneDude
  • Banned
  • Banned
10 Aug 2022 09:27
#871979
i instaaled it today. didnt need the hassle and decided not to relocate it.
