running lights both pulse when either turn signal is on
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
11 Jul 2022 00:29
#870179
is there a way to fix when running lights both pulse when either turn signal is on?
1982 KZ1100D1
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: running lights both pulse when either turn signal is on
11 Jul 2022 00:52 - 11 Jul 2022 00:53
#870180
I am assuming that you have the three wire turn signals ? if so it sounds like a ground problem for the light units. You can connect a voltmeter (black to battery ground - red to ground wire at turn signal) when you operate the lights you should have no more than 0.3v showing on the meter with everything connected . Any more than this indicates a bad ground
Last edit: 11 Jul 2022 00:53 by Wookie58.
The following user(s) said Thank You: Gdailey2112, bugkiller82
  • Mikaw
  • Mikaw's Avatar
11 Jul 2022 06:26
#870185
Check for corrosion in the socket it can backfeed power to the ground
The following user(s) said Thank You: Gdailey2112, Wookie58
