can't get gauge lights working
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
20 Jun 2022 19:27
#869142
had a problem with my ignition switch recently
when removing switch the lower end had just fell apart
after cleaning the contacts up real good id reassembled with dialectric grease and reinstalled.
solved many problems but just cant seem to get any gauge lights working
not sure if related to ignition switch but i dunno
thanx
1982 KZ1100D1
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: can't get gauge lights working
21 Jun 2022 00:13 - 21 Jun 2022 00:33
#869152
Is this the gauge "back lighting" you are talking about or the warning lights as well (oil pressure, neutral etc) if you are talking about the "back lighting" check the voltage on the Red/Blue going into the instruments (with everything connected and switched on) - this supply comes from one of the 10amp fuses (Red/White wire out of the fuse box) should be within 0.5v of battery voltage
Last edit: 21 Jun 2022 00:33 by Wookie58.
  • Gdailey2112
  • 82 KZ1100D1
21 Jun 2022 09:14
#869166
wookie yes its the back lighting and not the warning lamps
im going out to check voltage on red/blu feed will post findings
thanx wookie
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
25 Jun 2022 11:55
#869335
so i tested for continuity from where the wire connects to doide (male blade end by fuse box and with the diode disconnected from loom)
and tested continuity to connector inside head lamps housing (four prong connector)
i had continuity at r/blu
with red probe on the end by fuse box (r/blu wire) and the black probe then on the four prong connector inside head lights housing
not only did i have continuity on r/blu   strangely enough i also had it on brown and the wht/yel   is this normal
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
25 Jun 2022 12:45
#869336
the diode by itself pulled from circuit was tested using diode mode on voltmeter
it was reading .447v
tried to test ohms and it started out at 3.47 M ohms and steadily climbed to infinity
dunno if any of that helps
1982 KZ1100D1
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
25 Jun 2022 14:01
#869343
Forget doing continuity tests and taking resistance readings, you need to check voltage with everything connected and the circuit turned on as I said previously - going about it the way you are will send you down a rabbit hole
What is the voltage on the red/white coming out of the fuse box ?
What is the voltage going into the instrument cluster ?
