Replacing rectifier/regulator for 1979 kz650b3
- Missile2511
20 Jun 2022 13:28
Hello all,
I am looking at rectifiers on line for my 1979 kz650b3 and I have a few questions. They range in price from $35 to $150 and I am wondering if the expensive ones are much better or are they simply overpriced. Secondly, all of the units I find have 4 leads, 2 yellow and a black to the plug and a red with a pin connector. My regulator has 5 leads, the 5th lead is a brown lead with a pin connector. If these regulators on line are true replacements, what am I supposed to do with the brown lead?
Thanks,
Joe
Thanks,
Joe
- bluej58
Re: Replacing rectifier/regulator for 1979 kz650b3
20 Jun 2022 15:54 - 20 Jun 2022 15:55
I replaced my original rectifier and regulator with a modern combo unit from this guy about 6 years ago for around a hundred bucks "I think" it was pretty much a plug and play,
Works great and opened up a nice spot for a modern (blade style) fuse box.
My bike is a 78 1000 and I'm not sure if yours is the same setup but it is worth a try, good luck!
[email protected]
[email protected]
78 KZ1000 A2A
Last edit: 20 Jun 2022 15:55 by bluej58.
20 Jun 2022 16:38 - 20 Jun 2022 16:40
No eBay APP ID and/or Cert ID defined in Kunena configurationThe best 3 phase R/R's are SERIES type, which help protect your stator from cooking itself. Shindengen SH775 is the denotation, and they can be had for about $50 from ebay (used.) Don't buy from ebay unless SH775 is printed on the top fin. There are lots of fakes around. Triumph sells an adapter harness for about $10. Going this way is a little more fussy than buying a $100+ plug and play unit, but those are shunt type and inferior, so it's worth the slight extra work.
eBay item number:
384953978912
To get the ebay link, hit quote when replying to my post, and you will see the link. The forum software knocks down ebay links these days for some reason.
eBay item number:
384953978912
Last edit: 20 Jun 2022 16:40 by Nessism.
- Missile2511
20 Jun 2022 17:14
Great feedback, as always.. my current rectifier is a shindengen. I will have to check to make sure it is a sh775. I will look on eBay.
thanks
Joe
thanks
Joe
- Missile2511
20 Jun 2022 17:25
Looked on eBay, but I still don’t see any rectifiers with the fifth brown lead. That lead brings power to quite a few components, like the horn and others. What do I do with the missing brown lead?
joe
joe
- gd4now
- Denco where did you go?
20 Jun 2022 17:39
Info I have indicates the use of the additional brown line started in 1980. It is a sense line of what the entire electrical system draw is.
I have attached a file / table that shows the different charging systems on the 650s with stock part numbers
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
20 Jun 2022 19:59 - 20 Jun 2022 20:13Info I have indicates the use of the additional brown line started in 1980. It is a sense line of what the entire electrical system draw is.
Can a 3 phase R/R be used on a 1 phase charging system? If not, my apologies to the OP.
Edit: an internet search suggests that a 3 phase R/R will work with a 1 phase generator, but it's not ideal. Something about the total number of diodes doing the work and the system stress will be higher in the R/R than using a proper 1 phase R/R.
Last edit: 20 Jun 2022 20:13 by Nessism.
- Missile2511
21 Jun 2022 04:51
That chart disagrees with the wiring diagram in my clymer manual which does show the 5th brown lead on a 1979 kz650b3 r/r. Maybe they changed mid year.
- Missile2511
21 Jun 2022 04:57
I suppose that if the brown was added as a sensor for total system load, it should be expendable. Simple is good!
thanks again,
Joe
thanks again,
Joe
- H1Vindicator
21 Jun 2022 05:32 - 21 Jun 2022 05:34
rick's motorsport electrics may have a single phase voltage regulator.
diagrams.kz650.info/wiring/WiringDiagrams.htm
www.partzilla.com/catalog/kawasaki/motorcycle/1979/kz650-b3
Last edit: 21 Jun 2022 05:34 by H1Vindicator.
- gd4now
21 Jun 2022 06:47
It could be that some 79 model year bikes did have the 5 lead r/r. Here are the FSM wiring diagrams for the B3 models, note 1 phase r/r.
1977 KZ650 B1
- Missile2511
22 Jun 2022 09:59
Bought a new r/r with 5 wires from mad hornets. Fingers crossed.
