powered flasher module
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
04 Jun 2022 18:06
#868244
Was there a mod for the turn signal flasher that replaced the stock flasher with a flasher that has a power lead? I have this mod on my 76kz900b and cant recall why i did it years ago?
the flasher is directly powered from the batt, then the 2 flasher leads attach to the remaining 2 terminals.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: powered flasher module
15 Jun 2022 13:36
#868843
Normally a powered flasher unit is used when you don't want it to be current sensitive (LED flashers etc where the bulbs are not the stock wattage)
