1980 kz 550 ltd 5 wires on new rectifier and 4 on old one
  • Ivesy
  • Ivesy's Avatar Topic Author
02 Jun 2022 16:53
#868074
Hi everyone, newbie question for you.
Bought new regulator rectifier for my bike new one has 5 wires old one only had a 4 wire plug Rick's told me I could convert it to 4 wire.  There are 3 yellow a black and a white  how do I hook that up?
1980 kz 550 ltd
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: 1980 kz 550 ltd 5 wires on new rectifier and 4 on old one
03 Jun 2022 09:52
#868144
I do not mean to mislead you, but I think the 1980 models came stock with a single phase alternator ( 2 yellow wires from alternator to rectifier) and the new unit is make for a 3 phase alternator (3 yellow wires from the alternator to the rectifier) but it can be used for a single phase system but making use of 2 of the yellow wires.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Ivesy
  • Ivesy
06 Jun 2022 03:23
#868345
 I believe you are correct. So I understand the extra yellow isn’t connect to anything just capped off?
thanks
1980 kz 550 ltd
  • gd4now
  • gd4now's Avatar
06 Jun 2022 09:32
#868356
As I understand it yes, but there are others here who are more knowledgeable than I and will most likely chime in on the subject.
1977 KZ650 B1
  • H1Vindicator
  • H1Vindicator's Avatar
07 Jun 2022 11:23 - 07 Jun 2022 11:23
#868424
3 yellow wires would be for a 3-phase. 2 yellow are single phase.  a 1980 550 could have had either one or the other charging systems.  the diagrams at partzilla differentiate between the two system & I don't think the reg-recs are interchangeable.  but not certain.
Last edit: 07 Jun 2022 11:23 by H1Vindicator.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
07 Jun 2022 14:26
#868438
You can use any but only 2 yellow wires of the recifier on your wiring harness and capped of the 3rd, it does´t matter.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
07 Jun 2022 18:10
#868461
How many yellow wires are coming out of the generator?
  • martin_csr
  • martin_csr's Avatar
08 Jun 2022 15:19 - 08 Jun 2022 15:21
#868516
OP needs to list all of the wires.  He's saying his old voltage regulator has a 4-wire plug, but that might just be what's routed thru the connector & there could be an additional wire from the reg-rec (possibly white-red). loudhvx has wiring diagrams on his motorcycle stuff page.
Last edit: 08 Jun 2022 15:21 by martin_csr.
  • Ivesy
08 Jun 2022 17:16
#868529
Ok so I've done more reading on this forum... great stuff btw... the wires coming from the stator are putting out 26-29 ac volts at idle and 65 at around 4000 rpm.  The wires also get hot to the touch and the battery shows a discharge.  Once the bike cools off the battery is fully charged again unless you ride until it stalls.
it is for sure a single phase stator. Not sure what to think.
thanks for the replies and help
1980 kz 550 ltd
