What is the black box in front of the fuse box on a points based KZ400?
- YamaKawa
26 May 2022 01:29
Ok so I have a 79 400H1. Still runs on points. On the left side, I have the starter solenoid and the regulator-rectifier. On the right side I have three things: one that is obviously the flasher on the very back, one in the middle that is very clearly labeled "fuse box" (or "fuse panel"), and one on the very front with what looks like a four wire connector. No markings, no labels...I can't even find it in the parts diagrams on Partzilla!
Would this be the box I change out to switch to CDI? If not, what is it? I don't have a picture now but can take in the morning if need be.
1985 Yamaha XJ700N Maxim (airhead) - SOLD
1979 Kawasaki KZ400H (LTD), bought with 8416 original miles. - 'Tis my baby
1978 Honda GL1000 - SOLD
1995 Suzuki Katana - SOLD
Re: What is the black box in front of the fuse box on a points based KZ400?
26 May 2022 03:01
What colour are the wires going to it (I think it may be a brake light failure unit)
- DOHC
- Those Doe-Hawks really go!
26 May 2022 05:25Ok so I have a 79 400H1. Still runs on points.
Definitely not. A motorcycle with points doesn't have any ignition related black boxes. The points connect directly to the ignition coil. Other than points and coils, there are no other electrical parts.
If you were to change to electronic ignition, you might need to add a box somewhere. This was true with the old Dyna III system.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
26 May 2022 10:49
Have you looked at the wiring diagram in the fsm?
www.kzrider.com/modules/ServiceManuals/7...chablefullmanual.pdf
26 May 2022 11:18The only thing I could see on the diagram was the brake light failure unitHave you looked at the wiring diagram in the fsm?
- willemZ900
- Z1B 4 ever
27 May 2022 07:46
Pics of the box?
