KZ750H regulator/rectifier
- BobZ
29 Apr 2022 13:44
I ordered a reg/rec from Parts-n-more. On their website they showed a Shindingen part...the one they sent was a Rick's. That's not the issue though. The Ricks only has 4 wires in the plug instead of 5 in the one that came off the bike....there is no brown wire...just 3 yellow and a black. Is this going to work? It's the one they list for an 82 750H
Had I known I'd live this long I'd have taken better care of my Led Zeppelin albums
1983 Goldwing Interstate
1982 KZ750 LTD
1982 KZ750 LTD
- H1Vindicator
Re: KZ750H regulator/rectifier
29 Apr 2022 14:06 - 29 Apr 2022 14:11
I'd say yes. brown wire is the voltage sensing wire, but the Ricks reg-rec probably has the voltage sensing built into the circuitry. and just to be sure, I'm assuming the ricks unit also has a power wire not routed thru the connector, either: red, white or red/white.
Last edit: 29 Apr 2022 14:11 by H1Vindicator.
The following user(s) said Thank You: BobZ
- BobZ
29 Apr 2022 14:12
Yes ....there is a power wire.
1982 KZ750 LTD
1982 KZ750 LTD
- Irish Yobbo
01 May 2022 15:15
A 4-wire is generally a better design than the 5 wire, so you could call it an upgrade. The 5-wire system uses the accessories circuit to set the charge voltage which has a big flaw - too much draw on the accessories results in a voltage drop, and the regulator will increase voltage to make up for it. This means you can have 14.2V at your accessories and 15.2V at your battery, which will kill the battery. On these older bikes this can happen just from turning on the headlights on some bikes.
1981 KZ750 LTD
