M.unit to coils
- F64
- 81-KZ440D2
Re: M.unit to coils
21 Jun 2022 09:24 - 21 Jun 2022 09:25
I couldn't find an exact schematic for your bike, but found one for a 83 zx750A1.
That reg/rec has the same wire colors.
White goes to always on +12V.
Brown/white goes to switched +12V
This wire may operate as a voltage sense wire. On the stock system on a 83zx750 it ties into the brake light switch, the horn, and the turn signal relay.
You are eliminating these paths with the m-unit. So you may need to wire it to the light circuit or one of the aux outputs on the m-unit. Someone else may be able to clarify this.
black/yellow goes to ground
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 21 Jun 2022 09:25 by F64.
- Jai88
Re: M.unit to coils
21 Jun 2022 09:30
Thanks F64 that’s brilliant. I’ll probably run the brown white from Aux and see how I get on
