weak spark
  • Andyp62
  • Andyp62's Avatar Topic Author
Re: weak spark
13 Apr 2022 02:46
#865329
Yes my meter has resistance setting I will check it
thanks
1978 Z650 B2, US import to the UK
  • Andyp62
Re: weak spark
13 Apr 2022 02:49
#865330
Thank you
  • Andyp62
Re: weak spark
29 Apr 2022 01:52
#866339
I will try the relay, i see different amp relays available, any idea what amp i would require?
thanks
  • Andyp62
Re: weak spark
29 Apr 2022 01:57
#866340
I have bought coils from Z power, i am not sure what the resistance is but they said they would be compatible with the bb system
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: weak spark
29 Apr 2022 02:07 - 29 Apr 2022 02:10
#866341
thanks
Hi Andy, if you have 4 ohm coils they will draw approx 3amps each, since at times both coils are powered simultaneously you would need to double that to 6amps. You then need to allow for that figure changing due to voltage variations so I would suggest a relay rated at 10amps or above
If they are 2ohm coils (unlikely) the current draw would be 6amps each so you would be best to use a relay rated at 20amps or above. (Using a slightly heavier relay has no detrimental effect)
Last edit: 29 Apr 2022 02:10 by Wookie58.
  • Andyp62
Re: weak spark
29 Apr 2022 02:20
#866342
thanks for the message, in the wiredgeorge relay mod if you have seen it, does the wire 12v feed to the ignition trigger unit just come off the same terminal as the feed to the coils?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: weak spark
29 Apr 2022 02:32
#866343
The relay i use for the wiredgeorge mod.
The following user(s) said Thank You: Andyp62
  • Warren3200gt
  • Warren3200gt's Avatar
Re: weak spark
29 Apr 2022 02:38
#866344
The diagram I posted earlier in this thread shows where you make connections.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: weak spark
29 Apr 2022 02:58
#866345
Ref the live feed for your "BB" ignition trigger, yes I would also take this from the output side of the relay (new coil feed) to ensure best possible performance
