Battery cable size
- Ojisan rider
Battery cable size
07 Apr 2022 23:50
Aloha guys.
As the title reads, does anyone know what is the battery cable size, both positive and negative? I did a search using battery cable but could not find what I was looking for.
Planning to make my own battery cable as I did a R&R on harness and changing the fuse box, so there's some changes I need to make but most of all, my cable is just too damn hard to make any bent to it.
BTW, it's for 82 KZ/GPz 750.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
- Warren3200gt
Re: Battery cable size
08 Apr 2022 02:23
Easiest option is go buy some cheapo jump leads. Chop off what you need. Jump leads are colour coded red / black. Reconnect the Croc clip and get free + - battery leads and a set of jump leads for the toolbox.
The following user(s) said Thank You: linuxrob
08 Apr 2022 06:54 - 08 Apr 2022 07:04
If you don't get an answer, measure the core of your old cables where the battery lugs are crimped on.
6 AWG = 4.1mm diameter. 4 AWG = 5.2mm. Consult a wire gauge chart for other diameter measurements.
ps: a marine supply or welding shop might have thick wire.
Last edit: 08 Apr 2022 07:04 by martin_csr.
- Ojisan rider
08 Apr 2022 18:50
Thanks guys. I'll settle with what martin has suggested. I can always go bigger, just want to stay away from getting smaller (Hmmmmmmmmm. Heard this before somewhere..............).
Was kinda looking for easy way out (getting lazy. Also called getting old).
Anyway, once again, thanks guys.
- F64
- 81-KZ440D2
08 Apr 2022 19:22 - 08 Apr 2022 19:45
You may be able to find wire and lugs at West Marine.
www.westmarine.com/stores/honolulu-hi-1294
www.westmarine.com/marine-wire
I'd probably run 6awg. My bike's starter pulls 80amps.
To handle that without much of a voltage drop, I went with that size.
The battery cable at West Marine should be a lot more flexible than what you have.
You can also buy it by the foot.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 08 Apr 2022 19:45 by F64.
08 Apr 2022 23:23
If you use the calculator in my fault finding guide (FAQ section) you can feed in the current draw (work on 100amp) and the cable length. You can then enter different cable sizes until you get to a volt drop of less than 0.5v
