Kawasaki kz650B commutator left / right .
- CARLOS
05 Apr 2022 08:39
Hello, I am restoring a Kawasaki KZ650B from 1977 and I would need to find the left commutator and the right commutator, I think the original Kawasaki references; right 46091-1031 and left 46091-056.
Could you help me? I would like them to be originals and not reproductions, I don't care if they are new or second hand.
Thanks in advance for your help.
Re: Kawasaki kz650B commutator left / right .
05 Apr 2022 15:09
Commutator ? Ed
The following user(s) said Thank You: TexasKZ
- 750 R1
05 Apr 2022 15:17Commutator ? Ed
Switch blocks / hand controls
05 Apr 2022 15:21
Partzilla shows different part numbers.
www.partzilla.com/catalog/kawasaki/motor...7/kz650-b1/handlebar
- 750 R1
05 Apr 2022 15:24Partzilla shows different part numbers.
I just googles his number with "Kawasaki part" before it, hand controls showed up everywhere.
- CARLOS
06 Apr 2022 03:54
Yes, sorry I was referring to this command, in Spain we call it the light switch, according to the website where I look for the original Kawasaki reference it varies, here in partzilla it is this and I think it is the correct one 46091-1047.
I have looked for original or second hand and I can't find it, they are all reproductions.
Have you used any reproduction of this switch, or have you restored the same ones that your motorcycle has?
- Missile2511
27 Apr 2022 08:32
I have the left handlebar switch from a 1979 kz650b3. I replaced it because it was a problem. If you are going to rebuild it and just want the original case, then you can have this one for freight costs.
Joe
Joe
- gd4now
- Denco where did you go?
27 Apr 2022 11:33
The attached parts lists for the B1 and B2 models shows the part # as follows:
Left Hand side as 46091-056 for the B1
Left Hand side as 46091-1029 for the B2
Right Hand side as 46132-034 to use this part till gone replace with
Right Hand side as 46091-1032
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: CARLOS
