J2 ignition lock source?
- Warren3200gt
05 Apr 2022 05:37 - 05 Apr 2022 05:50
As title guys, it's not available for J1 & 2 any longer from khi. J3 repop is available from zpower but is totally different in both wire colours, mount and barrel length as the clock set for a j3 is different to a J1 & 2.
J1 & 2 is a 6 wire block with a seventh female spur.Anyone resolved this issue, if so how? or source of a repop or have a sh unit available for beer tokens?
Z1 Enterprises list the below as fitting J1, 2 & 3 but I know that must be incorrect as J3 is definately different at that list has J3 wire colour order.
www.z1enterprises.com/ignition-switch-w-...-J2%20J%20MODEL/1982
Last edit: 05 Apr 2022 05:50 by Warren3200gt.
Re: J2 ignition lock source?
05 Apr 2022 06:16 - 05 Apr 2022 06:27
Just to be sure, is your ignition switch part #27005-5019 with the slender key cylinder? I've seen this problem before w the narrow neck: one fix was to get a similar ignition switch from a later model, such as a Vulcan 750, but I don't recall exactly. need to do some checking.
www.partzilla.com/catalog/kawasaki/motor...tch-locks-reflectors
Last edit: 05 Apr 2022 06:27 by martin_csr.
The following user(s) said Thank You: Warren3200gt
- Warren3200gt
05 Apr 2022 06:21
Not exactly sure tbh Martin. I bought the bike in boxes and it was all present except........ the ignition barrel. As far as I have been able to workout it needs the one on the left below.
05 Apr 2022 06:28
The one on the left is #27005-5019, as mentioned above.
Here's a topic about the narrow cylinder. There's another topic I recall but haven't found it yet.
www.kawasakimotorcycle.org/threads/ignit...ompatability.185746/
- Warren3200gt
05 Apr 2022 06:44
I think your right Martin. Looking at the underside of the top yolk there is a half circle recess to match the lock. Plus the two bolt holes.
The J2 lock required is a 6 wire block plus a separate single bullit spur.
Wire colour layout is
Orange/green - brown - orange
White/black - red - white
Seperate spur is red/yellow.
It's unlikely another model switch would be an exact fit/wire layout so will have to get busy with a multimeter once I find one which will physically fit with the correct amount of wires.
05 Apr 2022 07:08 - 06 Apr 2022 05:15
The Emgo catalog has wire/pin info on some of their ignition switches. see catalog starting on pg 305.
emgowebsite.04833d7.netsolhost.com/wp-co...eneral_IN-2967-1.pdf
Partial list of similar ignition switches w the slender lock cylinder. not all years listed. a couple of OEM or aftermarket may be available.
1981-82 KZ1000-J1/J2 = 27005-5019
1984 ZN700/1100 = 27005-5040
1986 EN450 = 27005-5044
1986 VN750 = 27005-5052 >> this is the ignition switch that was used on a KZ1000-K Ltd.
1986-87 ZL600/900/1000 = 27005-5045
1986-87 ZN1300 Voyager = 27005-5034
Edit Vulcan 750 w photo: www.partzilla.com/product/kawasaki/27005...b74e203821080f95ac3f
Last edit: 06 Apr 2022 05:15 by martin_csr.
- Warren3200gt
05 Apr 2022 07:52
Hmmmm, seems to be 7 wire quantity is the stumbling block.
They all seem to be 5 wire or 6 at most.
- Warren3200gt
05 Apr 2022 12:25
I think I have tracked down the original thread you mentioned below Martin. Looks to be the solution I was after, thanks.
Just got to find one at a good price this side of the pond now.
www.kzrider.com/forum/4-electrical/61386...n-1981-82-kz1000-ltd
The following user(s) said Thank You: martin_csr
05 Apr 2022 16:13 - 06 Apr 2022 05:19
Thanks. Yes, that's it. I thought it was on the other forum & never looked here on KZR. doh. There may be an Emgo available.
Edit: you might be able to find a good used VN750 part. 27005-5052 was used until at least 2006.
Last edit: 06 Apr 2022 05:19 by martin_csr.
