1982 ltd 1000
  • zambulu23
  • zambulu23's Avatar Topic Author
1982 ltd 1000
03 Apr 2022 19:22
#864848
When I apply the brakes, front or back,  speedometer drops to zero.
When I let off the brakes,  speedometer needle resumes.
Turn signal flash slow.  Too much time between flashing.
Battery not charging.
I put a new regulator on.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1982 ltd 1000
04 Apr 2022 11:28
#864890
Undo and clean all you battery and earth connections, obscure faults are normally the result of "corrosive resistance" on the terminals of shared circuits like earth lines
