Symptoms of a Failing Ignition Coil
- ShaneDude
- Banned
11 Mar 2022 11:13
I have a 1977 KZ750B Twin
Its been acting funny lately. First of all, the starter clutch gear is shot, so fixing that.
I am now noticing, after changing the spark plugs, that one plug is dark but not fouled, and the other is fine. Carbs are in good shape, but I notice the idle racing somewhat, but not often.
A friend said that coils on Twins go fail often because of vibration. For giggles, Im going to change the coil this weekend as I had a brand new spare.
Is poor running and one plug darker than the other, a symptom of failing coils?
The following user(s) said Thank You: KZmarcel
- Warren3200gt
Re: Symptoms of a Failing Ignition Coil
11 Mar 2022 13:04 - 11 Mar 2022 13:05
Fouled how? Black carbon build up can be a sign of weak spark, over rich mixture or burning oil and/or low compression.
Last edit: 11 Mar 2022 13:05 by Warren3200gt.
12 Mar 2022 07:46
If it's an original/stock coil, then it could be that the windings are bad or the wires going into the coil have bad connections, especially the plug wires which might not be easy to fix since they're molded into the coils & not intended to be removed.
- ShaneDude
- Banned
13 Mar 2022 06:36
Thanks for responding. I changed the coil about 4 years ago.
13 Mar 2022 11:47
If the carbs are good the difference could be due to hardened manifold rubbers leaking air - you could try spraying WD40 etc round the rubbers with it idling and listen for a change in engine note
- ShaneDude
- Banned
13 Mar 2022 11:48
Was on it today. Its backfiring upon deceleration as well. I think its the coil. This happened 4 years ago
- Gdailey2112
- 82 KZ1100D1
19 Aug 2023 09:43
Just a thought, one big cause for backfiring upon deceleration is that of too small of pilots, doh just noticed user is blocked
1982 KZ1100D1
19 Aug 2023 16:52
It's easy to check a coil. Measure your primary and secondary resistance. If they are in spec then the coil is fine. It may be your voltage to the coil is low. Check and clean all of the contacts or maybe do the Wired George coil wiring change.
