Ignition key
- willemZ900
- Z1B 4 ever
Ignition key
13 Feb 2022 02:08
My Ignition key Z5729 is in bad shape, is it possible to find a key with the same number or must i find a brand new key and make it fit to my bike.
Does on the forum somebody know what my possibilitys are ?
- hugo
- '92 Zephyr 750
Re: Ignition key
13 Feb 2022 02:18
It only has the be similar blank, and any locksmith shop would cut a duplicate, if original is still decent. You can find blanks on line, or there are also locksmith stores carrying them, if you show them the original.
The following user(s) said Thank You: willemZ900
Re: Ignition key
13 Feb 2022 04:45
There are keys for sale on ebay all the time. Have you checked?
- willemZ900
- Z1B 4 ever
- rstnick
Re: Ignition key
13 Feb 2022 06:24 - 13 Feb 2022 06:27
Yes, check the number on ebay and you might get lucky to find new ones.
I can cut a key by the code number, to factory specs.
As long as your ignition is not badly worn, it should work better.
See this post:
Making a key by the code number. - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Send me a message if you want some info.
Rob
See this post:
Rob
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 13 Feb 2022 06:27 by rstnick.
