connection starter relais
- willemZ900
- Z1B 4 ever
01 Feb 2022 12:05
undefined The old starter relay of my z was torn and now put another one on it. The relay has two poles, one from battery plus (red) to relay and the second (black) from relay to starter.
Question: Does it matter or does it not matter on which pole of the relay the red and black go to, I don't think it matters but I'm not sure. I'm asking this to see how best I can get rid of the cables later on.
Willem
Willem
Re: connection starter relais
01 Feb 2022 13:11 - 01 Feb 2022 13:12
I doesn´t matter. The starter relay is only a massiv switch unit to deliver the higher current (Ampere) flow both ways between the battery and starter motor.
Last edit: 01 Feb 2022 13:12 by Scirocco.
The following user(s) said Thank You: willemZ900
