Battery ground wire
  • woodyvale
  • woodyvale's Avatar Topic Author
Battery ground wire
07 Jan 2022 01:34
#860142
I'm going to replace the old earth lead from battery to engine bolt as mine seems a bit old and crunchy.
The oem cable is not available anymore. I'm wondering if its OK to use one meant for a car - however they all seem a bit thicker than my original.
Just thought I'd ask the question before I tried to hunt down one that's nearer the oem thickness. Bike is a Gpz11 uni.
We're a bit limited for bike spares here in western australia, hence why I'm looking at autopart stores.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: Battery ground wire
07 Jan 2022 01:51
#860145
electricity will not know the difference,,,,,,,,,,,,,,,,,, as long as is same diameter or bigger.
The following user(s) said Thank You: linuxrob, woodyvale
  • linuxrob
  • linuxrob's Avatar
07 Jan 2022 04:36
#860147
Make sure it is a stranded wire not solid, just bigger than OEM and WELL crimped both ends, clean up the crankcase around the bolt hole and run a tap down the treads to get the best connection you can. My Z500 cable has a small negative wire off it as well but an additional neg wire is easy to loop into the loom. While your at it you can run extra negs from various arts of the frame to the engine neg connection.
1980 Z500 B2 owned from new 78260 miles
1980 Z500 B2 in bits since 1982 23000 miles
2004 GSF1200S Bandit K4
2000 GS125 ESD
The following user(s) said Thank You: woodyvale
  • woodyvale
07 Jan 2022 05:06
#860149
Cheers guys, good advice. Good to know i can use thicker wire.
  • Mikaw
  • Mikaw's Avatar
07 Jan 2022 08:40
#860152
Additional bit of advice. Compare the actual stranded cooper sizes. Just because the OD is bigger doesn’t mean it’s a larger gauge cooper. For example. Modern jumper cables. Big thick wires must mean they are good, NOT,  tiny cooper wire with thick insulation. Just make sure you are getting a heavy gauge wire as a replacement.
  • woodyvale
07 Jan 2022 15:00
#860208
Thanks Mikaw, I’ll check out the core before i hand over the cash.
