Lighting coils kz1000A
  • Samminorwich
  • Samminorwich's Avatar Topic Author
09 Nov 2021 01:40
#857703
Hi people another boring question but I am new to this
my kz1000A has no lighting coil and my main wiring harness has been cut around
Question does my engine have a lighting coil with a 6 way block connector and other wires or 3 separate wires , are these new coils any good I guess from china and is buying second hand risky as they might not work
many thanks love these cool bikes
  • martin_csr
  • martin_csr's Avatar
Re: Lighting coils kz1000A
09 Nov 2021 05:41 - 09 Nov 2021 05:44
#857708
Partzilla has parts diagrams, so you might be able to figure out what's what.  Please note that everything shown in a diagram may not be applicable to your model year as a particular diagram may cover 2-3 yrs >> the charging system components for example.  Early models may have a separate rectifier & voltage regulator, while a later model could have a reg-rec combo unit instead.  In some cases you can use the later stuff.  Another example is the ignition system >> early models could have points ignition while the later ones could have electronic ignition w igniter.  Also, somebody could have swapped out components already.
Last edit: 09 Nov 2021 05:44 by martin_csr.
  • Rick H.
  • Rick H.'s Avatar
09 Nov 2021 05:58
#857709
A few pictures of what you have may help readers figure out what you have....
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Samminorwich
16 Nov 2021 03:44
#857980
Will do soon
thankyou
  • hardrockminer
  • hardrockminer's Avatar
16 Nov 2021 04:47
#857981
What do you mean by "lighting coil"?  Do you mean ignition coil?  If so, you should have two, located under the fuel tank.
