electrical short ?
- CFD1976
electrical short ?
22 Oct 2021 20:39
my 76 kz 900 broke down the other day the positive cable was loose After tightning it still didnt start fuse was popped I didnt have a fuse so I hot wired it Bike started but immedlely started and smelled like wires burning After getting it home replacing fuse bike turn over but doesnt start Also I dont have to use a key it is always on I had to disconnect battery for lights to turn off
any ideas where to start thanking you in advance
Re: electrical short ?
23 Oct 2021 11:24
I’d focus on the ignition. Carefully inspect the entire harness. It might have melted wires together that now make the ignition switch inoperable
- F64
- 81-KZ440D2
23 Oct 2021 11:55 - 23 Oct 2021 18:37
I'll jump in tonight.
Driving to the racetrack now.
Which of the fuses was blown?
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 23 Oct 2021 18:37 by F64.
- CFD1976
23 Oct 2021 22:33
the main fuse when i hot wired it bike started right up but shut down within 2min started smelling and seeing smoke coming fron under th tank was wondering if coils might be the problem
they aer the originals have to check if its getting spark to the plugs and ill check the ignition all the wires under the tank seem to be intack put a new harness on 3 years ago Now if i connect the battery lights turn singnals horn all work but i dont have to the key in and if i put the key in doesnt change anything
- F64
- 81-KZ440D2
24 Oct 2021 05:07
Grab your voltmeter
Meter set to DC V
Bike must be on and everything connected.
Black probe on negative battery post(metal part of the battery. Not the battery cable)
Red probe on positive battery post
What is your voltage?
Move your red probe to your coils.
Measure each terminal.
What are the 4 voltages
Shut off bike
Meter set to DC V
Shut off bike
81-KZ440-D2.
LIC, NY
LIC, NY
The following user(s) said Thank You: CFD1976
- CFD1976
24 Oct 2021 09:30
DOES YOUR MEANING OF ON REFER TO BIKE RUNNING ? AS SOON AS TERMINALS ARE CONNECTED EVERYTHING IS ON WITHOUT KE;Y IN IGNITON .MOTOR TURNS OVER WITH STARTER BUT WILL NOT START. SO TO USE THE VOLT METER DOES THE BIKE HAVE TO BE LITTERLY RUNNING OR JUST ON ?
24 Oct 2021 09:46
Not trying to butt in as F64 is an expert troubleshooter, but seeing if the bike powers up by connecting the battery cables? You should assume the coils are getting power also. Untill known otherwise. If they are you can burn them out quickly have power to them without the bike running. F64 has correctly directed you to test power at the coils first. Just dont leave the battery connected too long till you know.
And no he’s not requiring you to have the bike started and running. By “on” he means 12v on
- F64
- 81-KZ440D2
24 Oct 2021 20:04
sorry,
your key switch is always on for some reason.
the kill switch needs be set to "on"
just don't hit the starter button.
i need to know if your coils are getting the exact voltage that you read at the battery.
81-KZ440-D2.
LIC, NY
LIC, NY
- CFD1976
25 Oct 2021 09:07
i really appreciate your advice I am going to get a new mutimeter today mine is about 50 years old and not dependable I will check reading and get back to you
- Kidkawie
- I bleed premix
26 Oct 2021 18:59
Sounds like the loose battery cable fried the harness. Also, not sure on the KZ but the Z1 has a spare fuse holder.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
