86 ZN1300 Spark plug wires.
  • cb900f
  • cb900f's Avatar Topic Author
02 Oct 2021 12:32 - 02 Oct 2021 12:49
#856090
Will be replacing the spark plug wires/boots on my 86 ZN1300 Voyager.  It seems the OEM spark plug boots are molded onto the wires.  No problem - will replace with new wires and screw-on NGK boots.  Curious if anyone knows if the original wires or boots are the resistor type?
Last edit: 02 Oct 2021 12:49 by cb900f.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 86 ZN1300 Spark plug wires.
02 Oct 2021 13:02
#856093
this is dependent of the spark plugs you want to use, only spark boots or spark plugs comes resistor type.
you have to choosen between resistor spark boots or resistor spark plugs but don´t use both together.
  • TexasKZ
  • TexasKZ's Avatar
02 Oct 2021 20:46
#856112
I think the factory installed resistor boots.
  • cb900f
04 May 2022 19:51
#866634
Just following up on this....
Seems the ZN is a bit of both.  Standard plug is BPR6ES - I believe the 'R' indicates a resistor type, and the wires are spec'ed as follows:
Seems to me that 3~6k ohms is low considering typical spark plug wire is 10~12 k ohms per foot and the longer wires are about a foot.
  • TexasKZ
  • TexasKZ's Avatar
04 May 2022 20:24
#866635
This chart shows non-resistor plugs. Resistors are not needed at all unless your Voyager has a radio, then either the wires or the plugs need to have resistors to avoid strong static on the radio.
