Loss of electrical power
  • Buck17
  • Buck17's Avatar Topic Author
01 Sep 2021 12:08 - 01 Sep 2021 12:25
#854691
Good Day,
I have a 1978 KZ400B1 I rebuilt recently and had out for one ride. The second ride I turned the ignition switch, pushed the start button and lost all electrical power. I checked the battery connections are clean and when checking conductivity found that if I unplug the right handlebar switch, which houses the on/off kill switch and starter button the neutral and oil pressure light will illuminate. I have purchased a new right side switch and if I plug in it will cut the connection and the lights will go out. I also installed a new ignition coil and have checked conductivity of the ignition switch, also good. Fuses have also all been checked with volt meter.
I have opened the wiring harness and found no bad or open connections. I am just about out of ideas and looking for potential solutions if anyone can suggest. Thank you!
Last edit: 01 Sep 2021 12:25 by Buck17.
  • loudhvx
  • loudhvx's Avatar
Re: Loss of electrical power
01 Sep 2021 12:43
#854692
Check fuses, wires soldered onto the ignition switch, and broken wires near where the harness goes from the frame to the steering assembly.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
13 Sep 2021 12:26
#855222
Do you have a wiring diagram you can send me, these things normally have a logical explanation
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
14 Sep 2021 06:17
#855244
Load test the battery.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
14 Sep 2021 12:16
#855260
Hi Buck 17
I have put together a test plan (attached) that may help. It's looks heavy but should only take about 20 minutes. Info for colours etc taken from a diagram for a 77 ( there isn't a manual for a 78 on here)
happy hunting
This browser does not support PDFs. Please download the PDF to view it: Download PDF
