Motogadget m-Unit Blue
- letthegoodtimesroll
31 Aug 2021 03:55
Over the winter I am redoing the electrical system on my '77 650 and will be installing the Motogadget m-Unit Blue and M-button. Has anyone done this and if so do they have a write up on it and a description of the new wiring harness? Thanks for any and all input.
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- Move0ver
Re: Motogadget m-Unit Blue
31 Aug 2021 06:43
I've used the basic, so close enough.
It's actually a pretty slick unit.
I HIGHLY recommend getting a ferrule crimper and using the proper ferrules:
The biggest thing is that the wiring is different than you're used to... The switch has a single signal wire that goes to the unit, and the unit has a power wire that goes to the light (vs the power going through the switch to the light).
The following user(s) said Thank You: letthegoodtimesroll
- Move0ver
31 Aug 2021 06:49 - 31 Aug 2021 06:52
Here's the wiring diagram I made for my GS750E. I think the diagram has a mistake in the high/low beam switch... I fixed it on the bike but never updated the diagram (I think the low beam shouldn't switch to ground? It's been a long time since I looked at it).
Last edit: 31 Aug 2021 06:52 by Move0ver.
- F64
- 81-KZ440D2
31 Aug 2021 08:35
Check out Revival cycles series of videos on the M-unit.
revivalcycles.com/motorcycle-videos/play...Cycles%20Tech%20Talk
Here's one.
revivalcycles.com/motorcycle-videos/899wODtXeRg
Here's one.
81-KZ440-D2.
LIC, NY
LIC, NY
- Move0ver
31 Aug 2021 08:48
I've watched a number of Youtube videos including the Revival ones but none seem to explain where the voltage regulator and rectifier go. I was hoping to be spoon fed with this. Lol! Thanks for your help guys. I will be handing this bike down to my son and I am just trying to modernize it.
- F64
- 81-KZ440D2
31 Aug 2021 08:54 - 31 Aug 2021 08:55
The voltage regulator/rectifier aren't really part of the m-unit circuit.
On my bike they exist by themselves with the battery and the stator.
What other specific things are you wondering about concerning the M-unit?
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 31 Aug 2021 08:55 by F64.
- Move0ver
31 Aug 2021 08:59
R/R on my wiring diagram is the regulator/rectifier. The stator feeds into that, which feeds into the harness.
generally, if you can, you'll want to upgrade the RR while you're in there
03 Sep 2021 05:29
I've actually found some pretty good diagrams online and hoping that this will go smoothly. I will also try and document the process in order to assist anyone looking to do this in the future.
03 Sep 2021 05:31
I ordered a crimper last night, thanks for the heads up!
