slow turn over
- ianj01
slow turn over
21 Aug 2021 21:01
1977 kz650b battery is fully charged but starter motor is slow to turn the engine over. starts ok on the kick starter. put the meter on the battery and pressed the start button and voltage drops to 6 volts. does this indicate the battery is faulty or the starter motor is at fault. any input is appreciated. cheers guys.
Attachment not found
- DOHC
- Those Doe-Hawks really go!
Re: slow turn over
21 Aug 2021 21:36
You measure 6V at the battery terminals under load? If you measure that at the battery terminals, your battery very likely has an internal fault and you need a new battery.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: ianj01
Re: slow turn over
21 Aug 2021 21:45
I think DOHC is on it. You can jump your bike with your car but do not start the car. I would disconnect the bike battery. If the charging see a 6 volt battery is gonna hit it with a spike voltage, I’ve had it happen and it blew every light bulb on the bike.
You can also take the battery to your local automotive store and they can test it. Charge it full first.
Re: slow turn over
21 Aug 2021 22:11
Could also be starter brushes or worn bushings. I almost bought a battery but it was the starter.
- ThatGPzGuy
Re: slow turn over
22 Aug 2021 06:33
Simplest/cheapest solution would be a bad ground. Check that first.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- DOHC
Re: slow turn over
22 Aug 2021 10:00Simplest/cheapest solution would be a bad ground. Check that first.
A bad ground would reduce the load on the battery, making it even less likely that one would measure 6V at the terminals.
Steve's suggestion about the starter motor would increase the load and possibly make it droop more, but 6v is very low.
I like the suggestion of substituting a car battery as a test. If it starts normally from another battery then the existing battery is probably the issue.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: SWest, Mikaw, ianj01
Re: slow turn over
22 Aug 2021 10:30
Rule out the battery/connections first. If the starter drags with another battery it could be bad. A larger battery could make it work but it won't spin as normal. I'll be buying brushes for my starter being the bushings are good.
Look for the bike you have.
ricksmotorsportelectrics.com/Starter-Motor-Brushes-70_103
Re: slow turn over
22 Aug 2021 10:32
Check the acid level of the battery cells!!! One dry or half full cell(s) can effect a huge voltage/current drop if you use the starter motor.
The following user(s) said Thank You: Mikaw, ianj01
- ianj01
Re: slow turn over
23 Aug 2021 03:33
tried to start using the car battery and starter motor is still slow so it looks like the brushes in the starter motor are worn
so i will pull the starter out and give it a good dose of looking at, cheers for the input guys.
Re: slow turn over
23 Aug 2021 08:10
Be sure the bushings aren't worn out. If they are the brushes might work but not for long. I use to buy the rebuild kits but they are hard to find now. I wound up buying a low mile starter mainly for parts. When I get my new brushes I'll take the best parts from both and make one good one like I did the last time.
