KZ550 Hazard lights not working
- kzMax
Re: KZ550 Hazard lights not working
05 Aug 2021 20:47
It's getting pretty late, so I'm going to come back and try to figure this out tomorrow. Thank you for all your help so far!
1982 KZ550 A3
Central MA / Boston
Central MA / Boston
- F64
- 81-KZ440D2
05 Aug 2021 20:52
Definitely!
I'll check back tomorrow.
81-KZ440-D2.
LIC, NY
LIC, NY
- Sturmeyhack
29 Aug 2021 16:52
It might be a bad frame ground, or the switch itself might be dodgy. But given the turn-signals work and the hazards don’t, it’s probably a switch issue or hazard-circuit issue.
You could try opening up the switch and giving it a blast of contact cleaner. Check for corrosion in the switch contacts, sand lightly if needed, add a little bit of lithium grease, and reassemble. Check, clean, and grease the electrical connections, too.
2015 Versys 1000 SE
2010 Versys 650
1980 KZ550A1 (again)
2010 Versys 650
- kzMax
07 Sep 2021 12:59Thanks for the tip - I haven't really been working on this issue, as I was able to pass inspection without my hazards, so fixing them suddenly fell pretty low on my list of priorities. But your suggestions are definitely worth trying once I revisit this task!It might be a bad frame ground, or the switch itself might be dodgy. But given the turn-signals work and the hazards don’t, it’s probably a switch issue or hazard-circuit issue.
1982 KZ550 A3
Central MA / Boston
Central MA / Boston
