No spark Help needed
  • carnesir
  • carnesir's Avatar Topic Author
23 Jul 2021 23:34 - 24 Jul 2021 05:17
#852411
Hello! New member here. From Sweden. I am rewiring a KZ750 LTD 1982 and I have had it running earlier but now I cant get any spark. Narrowed it down to the igniter thingy. Can someone please help me with the wiring. Also putting in a m-unit. Thank you
Last edit: 24 Jul 2021 05:17 by Street Fighter LTD.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: No spark Help needed
24 Jul 2021 05:19
#852415
Welcome to KZRider
I fixed your picture to be full size
Next time please click the insert all tab to complete the picture install  process
The following user(s) said Thank You: Nessism, carnesir
  • F64
  • F64's Avatar
  • 81-KZ440D2
24 Jul 2021 06:48
#852420
Do you have the schematic for your motorcycle?
I can't find those wire colors on my schematics.
Is that the ignitor that came with your motorcycle?
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: carnesir
  • loudhvx
  • loudhvx's Avatar
24 Jul 2021 08:21 - 24 Jul 2021 08:25
#852431
Here's a diagram I drew for a U.S. Kz750K1 twin, based on a German Kz750K1 twin.
I'm not 100% sure what the pink wire was for (it's been a while), but most likely (99%) it was for a safety interlock, especially since wiring it to ground makes it work.
www.kzrider.com/forum/4-electrical/17274...ght?start=228#485190
Last edit: 24 Jul 2021 08:25 by loudhvx.
  • F64
  • F64's Avatar
  • 81-KZ440D2
24 Jul 2021 09:56
#852437
Thanks Lou!
That pink wire was confusing me.
Carnesir,
You'll wire your (yellow with red stripe) to the ignition output on your m-unit along with your positive coil wire.
(pink wire) and (black wire with yellow stripe) go to ground
(yellow with blue stripe) goes to coil negative
(blue wire) and (black wire) go to your ignition pickups
schematic courtesy of loudhvx
81-KZ440-D2.
LIC, NY
  • carnesir
24 Jul 2021 10:02
#852440
Thanx for all the replies.
Yes its the igniter that came with the bike
If I wire it up like the schematic the weird thing is that i have 12 v on the brown and pink wire. Am I missing something???
I wired as follows bl-bl, blk-blk, y/r to coil pos, bl/y to coil neg, blk/y to ground, Pink was left alone.
Is it possible to wire some other way?
  • carnesir
24 Jul 2021 10:06
#852441
@F64 I'll try that and see what happens
  • loudhvx
  • loudhvx's Avatar
24 Jul 2021 12:33
#852451
Pink needs to go to ground as well.
  • carnesir
24 Jul 2021 23:56
#852493
Starting from scratch this morning and found that there was missing wires in the right handlebar switch. Fixing that and then rewiring the complete bike. Thanks for all the help
