KZ900 right hand controls
  • motoaddict
  • motoaddict's Avatar Topic Author
19 Jul 2021 03:41 - 19 Jul 2021 03:42
#851998
I bought and installed a new reproduction right hand controls for my kz900. The blue wire connectors from the controls are a little different from the originals and do not directly connect. Anyone else have experience with how to properly hook this up? Currently have no functioning headlight but this might be unrelated.
1976 KZ900
Last edit: 19 Jul 2021 03:42 by motoaddict.
  • 73z1
  • 73z1's Avatar
Re: KZ900 right hand controls
19 Jul 2021 04:00
#851999
Plug the two male connectors into female connector.
  • hardrockminer
  • hardrockminer's Avatar
19 Jul 2021 04:01 - 19 Jul 2021 04:02
#852000
Try connecting that blue male to the blue double female.  Then take the blue male from your left control and connect to the blue double female on the right control.
By the way...that control is for a Z1, not a KZ.  There should not be any "ON-PO-OFF" on a KZ.  But it will still work.
Last edit: 19 Jul 2021 04:02 by hardrockminer.
  • motoaddict
19 Jul 2021 04:41
#852003
Thanks, I will try that out. It was advertised as for a Z1 or KZ. What do the blue wires even do?
1976 KZ900
19 Jul 2021 05:10
#852005
Not exactly true. My 1977 KZ650-C1 came new with the ON OFF switch.  It was somewhat later (1978?) that the headlights came on automatically when the ignition was turned on.  Ed
  • 73z1
  • 73z1's Avatar
19 Jul 2021 05:59
#852007
Blue wires power tail light and speedo light
  • jwfels
  • jwfels's Avatar
19 Jul 2021 06:11
#852009
hi, switched lighting or unswitched? if unswitched, in your old switch wiring under the sleeve, they spliced brown. (12v feed) to blue/white and brown/white, to return to fuses for lighting, the blue wire are switch legs from light switch (ring out), what did you do with the 4 pin connector on new switch?  remove and splice direct?  brown feeds ignition and lighting,   single blue is feed for light switch, some how splice to brown, (bullet connectors are best), plug blue/white and brown white into double blue, which,, will feed lighting fuses, good luck
Z1A AND 81 650
  • hardrockminer
19 Jul 2021 16:48
#852055
I suppose it depend on the original market.  Here in Canada the change was in 1975.  I had a Z1B back then with no lettering.  US market may have been different.
  • motoaddict
20 Jul 2021 03:43 - 20 Jul 2021 03:49
#852093
The original right hand KZ900 controls were switched unless someone at some point swapped it from a Z1? Also thanks for the wiring advice, I was able to get the headlight to turn on by experimenting with the blue wires. The headlight is not all that bright but the engine was not running. Maybe brighter then? Also the flashers and hazards dont work so I need to replace the relays for those. Also the turn signal indicator lamps to not seem to work. Do I even need these?
1976 KZ900
Last edit: 20 Jul 2021 03:49 by motoaddict.
  • hardrockminer
20 Jul 2021 04:12
#852095
I have two Z1Bs (1975).  One was built in Sept/74 with a RH control like the one you removed.  The other was built in Jan/75 with the control in the photo below.  If you look carefully you will see a tiny piece of plastic across the slit between the two halves of the control.  I also owned a Z1B back in the day with a control like the second one.
Just a guess, but I suspect the US market didn't require the headlight to be on all the time until a later year.  In Canada it was 1975.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
20 Jul 2021 05:30
#852099
motoaddict post=852093
Unless the internal switchboards are broken or completely trashed, that can very likely be restored.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • motoaddict
20 Jul 2021 08:03
#852107
Great! I will sell it you :)
1976 KZ900
