LED strip - brake/turn same wire
- loudhvx
Re: LED strip - brake/turn same wire
29 Jun 2021 15:09 - 29 Jun 2021 15:26
You can also make your own with a time-out circuit in case you leave the signal on.
There are a few options on this page, including an integrator you can build. It requires a ground a wire.
s3.amazonaws.com/gpzweb/Lighting/GPZturnSigInteg.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Jun 2021 15:26 by loudhvx.
29 Jun 2021 16:23
It would be easier to buy a second LED strip only for the running and brake light.
29 Jun 2021 16:25
I yeild my time to the experts.
- loves_guitar
06 Jul 2021 08:58
For anyone in the future that wants to know how this turned out:
I ordered a Curt brand non-powered 3 wire to 2 wire converter. I connected the wires, gave it a test.... and it did not work. I should have read closer to the description that the converter I bought would not work for LED applications.
So then I went to the local automotive store and got this Reese converter: Reese Towpower | 8507900 | Taillight Converter
That worked!
So in case anyone runs into an aftermarket rear light situation where the signals and brake share wires, use a trailer converter!
Thanks, as always, for your help guys!
That worked!
The following user(s) said Thank You: loudhvx, TexasKZ
- loudhvx
06 Jul 2021 09:08
Glad it's working. Thanks for the update. That will definitely help others, as more and more questions related to LEDs show up all the time.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Oldschoolkz1000
15 Jul 2021 18:23
If you havent tried to install the trailer box yet, this is definitely a better choice.
shop.revivalcycles.com/led-dual-element-circuit
I bought 4 of them for my bike lighting and they work great.
