Z1 Color Wiring Diagram?
  • Mikaw
  • Mikaw's Avatar
Re: Z1 Color Wiring Diagram?
13 Jun 2021 15:12 - 13 Jun 2021 15:15
#850144
The white connector is the coils and points. Black and green are points and it should have the yellow red for coils.
edit. The white connector might be the brake light failure switch. What are the colors
Last edit: 13 Jun 2021 15:15 by Mikaw.
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
13 Jun 2021 15:32
#850145
Thanks Mikaw, you're a Godsend.  This helps tremendously.  I wonder if this harness is used on the Cop bike?  Could the white possibly be Cop bike related?
KZ900; Z1
  • Robb2018
  • 76 KZ900 73 Z1 A
13 Jun 2021 15:51
#850147
On my KZ900 the brown and blue goes to the horn.  I'm wondering if the front brake line is run through the plug coming off the right handlebar control?
KZ900; Z1
  • Mikaw
  • Mikaw's Avatar
13 Jun 2021 16:12
#850148
Horn is brown and black. The black comes off the LH control separate, not in the connector. Brown is 12volt
The following user(s) said Thank You: Robb2018
  • Mikaw
  • Mikaw's Avatar
13 Jun 2021 16:25
#850151
Points connect to the coils thru a two wire harness from the points. Black and green. They connect direct to the coils.
  • Mikaw
  • Mikaw's Avatar
13 Jun 2021 16:27
#850152
  • Robb2018
  • 76 KZ900 73 Z1 A
13 Jun 2021 16:34 - 13 Jun 2021 16:35
#850153
I'll tell you, it's like someone set a monkey loose with a soldering iron and a wire cutter on this electrical system.  He's got splices and goofy connectors all over the place.  He had removed the panel under the right side cover and had this crap connected to a couple of these square connectors.  Then he replaced the rectifier with a solid state regulator rectifier and cut into the harness and spliced the leads. When I converted my first KZ to regulator/rectifier it came with a canon connector that just plugged into the panel.  Also, can anyone identify this regulator rectifier?
KZ900; Z1
Last edit: 13 Jun 2021 16:35 by Robb2018.
  • 73z1
  • 73z1's Avatar
13 Jun 2021 16:39
#850154
The three wire connector near the coils is part of the brake light warning system that appeared in 1974, warning light in tachometer, 28019-001
  • 73z1
  • 73z1's Avatar
13 Jun 2021 16:41
#850155
Aftermarket, not oem.
  • Robb2018
  • 76 KZ900 73 Z1 A
13 Jun 2021 16:47
#850157
That is .in fact yellow red with double fem connector.  Making more sense little by little.  What goes to the blacks coming off the coils?
KZ900; Z1
  • Robb2018
  • 76 KZ900 73 Z1 A
13 Jun 2021 16:50
#850158
73z1 post=850155
There's no name on it, just some numbers on the back that I can't make out.
KZ900; Z1
  • 73z1
  • 73z1's Avatar
13 Jun 2021 16:54 - 13 Jun 2021 16:55
#850159
The points plate has a long green wire and black wire that goes under engine then up to coils.
A yellow/red wire supplies +12 volts to the coils.
Last edit: 13 Jun 2021 16:55 by 73z1.
