Z1 Color Wiring Diagram?
Re: Z1 Color Wiring Diagram?
13 Jun 2021 10:40 - 13 Jun 2021 10:41
Personally I’d not use the clymer. Only as a reference. The FSM I posted is a color version.
Last edit: 13 Jun 2021 10:41 by Mikaw.
The following user(s) said Thank You: Robb2018
- Robb2018
- 76 KZ900 73 Z1 A
13 Jun 2021 11:17 - 13 Jun 2021 11:17
I have two of each. I'm calling Z1Parts tomorrow and having them exchange the two double wire.What a mess. Trying to start in the headlight, PO had so much spliced and run with different color wires, I can't just go through it methodically and remove and replace, which is what I had planned on doing. So I don't know if this aftermarket harness is adding to the confusion... but I'm assuming the two black plastic covered canon plugs are for the right and left handlbar controls? Then the diagram is showing b/y, r/y and b/r going to the headlight... got those covered. Then there's b/y and gr going to right turn sig and b/y and g going to left. (Just thinking out loud, let me know if I'm off on anything) So there's no green but in the same bundle there's a y/r, a gr a double br and a blue. My guess is since these are all bundled together, the what I'm seeing as blue, is supposed to be the green for the left turn sig? Then there's the pair of brown and blue... is that possibly for the horn? Ugh.. I'm getting a headache.
KZ900; Z1
Last edit: 13 Jun 2021 11:17 by Robb2018.
- Robb2018
- 76 KZ900 73 Z1 A
13 Jun 2021 11:20
Yes, I agree... Clymer sucks. and thanks for the color diagram Mikaw. That helps a lot.
KZ900; Z1
13 Jun 2021 12:11
6 pin is left hand control, 4 pin is right hand control. Blue and brown are front brake light. gray is Rh turn,green is LH turn they get the black yellow ground. Yellow red is coil power. Brown is switched 12v power. Brown white is extra 12volt power. Can’t find the solid red yet. Looks like it is the same as solid Blue it is switched Thur the headlight Rh control
13 Jun 2021 12:15
Something doesn’t look right about that harness. Can you show a picture of the whole complete harness
13 Jun 2021 12:33
Back when I was still working I had access to a high quality printer/plotter and printed this 3 ft by 5 ft version off an electronic PDF copy of the colour version. I think it's near the back of the manual.
The following user(s) said Thank You: BlackZ1R, Robb2018
- Robb2018
- 76 KZ900 73 Z1 A
Last edit: 13 Jun 2021 13:50 by Robb2018.
13 Jun 2021 14:48
The hand control connect at the red circle under the tank. The dash/idiot lights connect one in the blue circle. What throwing me off is the other in the blue circle.
13 Jun 2021 14:56
13 Jun 2021 15:00
13 Jun 2021 15:04
13 Jun 2021 15:10 - 13 Jun 2021 15:10
Last edit: 13 Jun 2021 15:10 by Mikaw.
