SH230-12 R/R Set Point
- nixon
13 May 2021 15:12 - 14 May 2021 11:45
Hi, just wondering if anyone knows what the voltage output of a SH230-12 reg/rec should be. This is from a 1981 KZ750 LTD-H.
thanks
thanks
Last edit: 14 May 2021 11:45 by nixon.
Re: SH230-12 R/R Set Point
14 May 2021 07:28 - 14 May 2021 07:31
Most folks probably aren't going to know what an SH230 is.
Is this a stock voltage regulator on a particular KZ model? That info would be more helpful.
I'm guessing yes. so probably about 14.5 VDC @ 4k rpms. but the numbers should be listed in the FSM.
Last edit: 14 May 2021 07:31 by martin_csr.
- nixon
14 May 2021 11:46
This is the stock reg/rec from a 1981 KZ750 LTD-H (four cylinder).
14 May 2021 13:07 - 14 May 2021 13:07
Okay. The numbers I posted above are probably correct.
There's an 80-85 750-4 chain drive FSM available & it may be linked in the filebase here. It's also at the 750Turbo site.
Yellow/Gold cover w color wiring diagrams. There's also a poorly copied B-&-W version, so be sure to get the good one.
Last edit: 14 May 2021 13:07 by martin_csr.
