Ignition coil question
- Claude.
26 Apr 2021 17:09 - 26 Apr 2021 17:09
We all know there are two coils; one for #1/4 and one for #2/3. So, if one coil fails, the engine will fire on the remaining pair of cylinders.
QUESTION: Is it possible for a coil to fail on only one cylinder? As like in an engine firing on three cylinders?
In such a case, I assume the culprit is probably more the spark plug, the cap or the wire but just to be sure, can it be the coil itself?
Thanks!
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 26 Apr 2021 17:09 by Claude..
Re: Ignition coil question
26 Apr 2021 17:36
The coil itself can't fail on one cylinder, but the high tension leads and/or the cap can. And don't forget the spark plug.
The following user(s) said Thank You: Claude.
- F64
- 81-KZ440D2
26 Apr 2021 18:50
I guess the coil secondary terminal could be cracked and is arcing to ground.
Turn the lights out, grab a spray bottle of water and mist water around the coil and the spark plug wires.
If it's arcing then you'll witness a good lightning show.
You don't need much water.
81-KZ440-D2.
LIC, NY
LIC, NY
- 73z1
- Zilla
29 Apr 2021 11:48
I normally take an extra spark plug and put it on the suspected spark plug wire and lay it in the head bump the starter and see if that on archs
1986 KZ1000P
2005 Vmax
2005 Vmax
