New rectifier for 77 Kz650
  • 504Ghost
  • 504Ghost's Avatar Topic Author
19 Apr 2021 10:16
#847034
I have an early 77 kz650 and I’m looking for a replacement rectifier. All are incredibly expensive that I’ve found$150-$250usd.  But I did find an aftermarket manufactured part from a UK shop. Was wondering if anyone had used it before??
www.rexs-speedshop.com/product/rectifier...saki-z650-21061-031/
thanks for the space
AndrewR
  • JB911
  • JB911's Avatar
Re: New rectifier for 77 Kz650
21 Apr 2021 14:16
#847173
I used a combination rectifier/regulator from an EX500, peanuts on eBay
I made a post on it with details if you search
Best,
JB
  • JB911
  • JB911's Avatar
21 Apr 2021 14:58
#847176
Here's the thread-it may also work on your KZ
www.kzrider.com/forum/4-electrical/61018...namo-stator?start=24
Best,
JB
21 Apr 2021 15:03 - 21 Apr 2021 15:04
#847177
I own a 1977 KZ650-C1 that I bought new back in 1977.  The rectifier died in 2012 and I replaced it with one from Oregon Motorcycle Parts.  Their rectifier number is Model R255a.  See 5 & 6 wire rectifiers at www.oregonmotorcycleparts.com/rectifiers3p.html .  It still works like new; I believe it is made better than the original Kawasaki part. I suggest you contact them to ensure that the part number is correct for your bike.  Ed
Last edit: 21 Apr 2021 15:04 by 650ed.
  • Nessism
  • Nessism's Avatar
  • Away
21 Apr 2021 15:44 - 21 Apr 2021 15:49
#847180
That bike uses an unusual field coil generator.  Does it use a conventional rectifier, or something special to go with the field coil system?
One option is to convert over to a common three phase system.  Parts could be purchased on ebay for pretty cheap.  I suspect this may be the cheaper way to go but more involved compared to buying a new part to fix your bike.
Last edit: 21 Apr 2021 15:49 by Nessism.
21 Apr 2021 16:16
#847184
The new rectifier I bought from Oregon Motorcycle Parts was only $50.  Ed
  • 504Ghost
21 Apr 2021 18:16
#847198
it is an early 77 kz650b1 with the three bolt cover. Excited coil system
I went with the Oregon motorcycle parts rectifier and regulator. After speaking wi tony over there, he explained how his reg unit will charge better under 4K rpm. Where the stock OEM unit barely charges the battery..
thanks for all the input guys.
a couple follow up questions,  anyone can shoot me a link for a downloadable factory Kawi service manual in pdf form? I found a couple sites, but none with my specific year and model
also looking to upgrade the headlight in the stock OEM. Bucket/gauges/ and plug, any recommendations?
thanks for the space guys
AndrewR
  • Nessism
  • Nessism's Avatar
  • Away
21 Apr 2021 18:37
#847201
AndrewR
Manual on this site in the Service Manuals section of the Articles tab.
From what I've read the Truck-lite lamps are amazing.  You can also get a shell that uses a halogen bulb.  Lots of sources.  Add a nice high power bulb for even nicer results.
  • 504Ghost
21 Apr 2021 19:05 - 21 Apr 2021 19:21
#847203
Thanks @nessism.  I actually just found the service manual a couple minutes after posting that reply.......dummy. Ha
as for the headlight, I have a buddy with a 27270c trucklite He bought for his Gs750 wasn’t  installed, because the bike was sold ..Will this work for my KZ650??
Last edit: 21 Apr 2021 19:21 by 504Ghost. Reason: Misspelling
21 Apr 2021 20:06
#847205
I use a Wagner H6024 halogen headlight in my KZ650.  It works great and is considerably brighter than stock without stressing the wiring.  Below is one place to buy them, but there may be cheaper places.    Ed
www.summitracing.com/parts/WAG-H6024
  • Nessism
  • Nessism's Avatar
  • Away
21 Apr 2021 20:09
#847207
Truck-lite's are LED so they are low wattage.  I don't know what size the original bulb it so measuring it would be the first step toward finding a replacement.  7" is common.  Anyway, Amazon has Truck-Lite bulbs so you might want to search around.
  • martin_csr
  • martin_csr's Avatar
22 Apr 2021 06:14 - 22 Apr 2021 06:18
#847222
My 81 KZ650-CSR had a sealed beam unit. very dim.  So I installed a lens unit & halogen lamp/bulb from a 1982 KZ750 Ltd.  It was a direct swap >> just needed the lens unit, dust cover & bulb.  pretty easy.  and now I can easily carry a spare H4 bulb in my tail-bag.  The lens unit was cloudy, but cleaned up w denatured alcohol.  I'm sure there are brighter options, but the H4 is certainly brighter than the stock unit.
Last edit: 22 Apr 2021 06:18 by martin_csr.
