No spark on 1 & 4
- Hips
Re: No spark on 1 & 4
18 Apr 2021 09:09
Excellent, thanks Mikaw
I have seen one on ebay from a kz550 that looks exactly like mine but not sure if compatible being a smaller cc engine
18 Apr 2021 09:17
No eBay APP ID and/or Cert ID defined in Kunena configurationThis one looks similar,but it’s missing the oil sending wire. You might be able to splice the pickups into your harness
Loudhvx is the guy that will know for sure.
18 Apr 2021 09:20 - 18 Apr 2021 09:21
No eBay APP ID and/or Cert ID defined in Kunena configurationI’m sure this is out of the budget, it would be out of mine for sure, but you can use it for reference
Last edit: 18 Apr 2021 09:21 by Mikaw.
- Hips
19 Apr 2021 11:21
Excellent thanks mikaw.
Yes definitely out of my budget but is definitely the one for my bike. I've tried to research different ones to see if they are compatible but none seem to list my bike but all the ignitors are comparable which connects to all coils. It looks exactly the same and the wires are the same so I can't find any reason why it wouldn't fit or work. Surely an engine which is the same apart from bigger bores still fires the same. But I'm no expert.
