@$%#$ Wiring *%#@ Diagrams!
  • slayer61
  • slayer61's Avatar Topic Author
  • KZR FLAG RELAY CARRIER #62
06 Apr 2021 07:16
#846261
Fellas I need some help please. I have put some ZN1100/750 gauges on my wife's GPz1100 because the originals are just hideous and not worthy of taking up space on the dash of a motorcycle. I think I have the GPz end of the harness sorted out, but for the life of me, I can't find a clear copy of the wiring diagram for the ZN gauges to make up a patch cable. Anybody got suggestions or donations of wiring diagrams? As a last result... I suppose I could split open the gauges & wring out the wires... Anyone?
  • 73z1
  • 73z1's Avatar
Re: @$%#$ Wiring *%#@ Diagrams!
06 Apr 2021 07:37
#846262
Can you use the original harness with the new gauges ?
  • martin_csr
  • martin_csr's Avatar
06 Apr 2021 08:21
#846266
Before trying to search, are the meters from the ZN1100 or ZN750 (ZN700 in the USA).  also, what year is the GPz1100?  Thanks.
  • slayer61
06 Apr 2021 08:44
#846270
Yes. It physically plugs in, but the GPz harness is just idiot lights & the ZN harness is speedo, tach & cluster lights.
  • slayer61
06 Apr 2021 08:47
#846271
martin_ wrote: Before trying to search, are the meters from the ZN1100 or ZN750 (ZN700 in the USA).  also, what year is the GPz1100?  Thanks.
The meters are from a ZN1100 (per ebay seller, & partzilla says they're the same from 1100 to 700) and the GPz is a 1981.
Thanks everybody. My wife will appreciate having the lights & such working!
  • martin_csr
06 Apr 2021 13:10 - 06 Apr 2021 13:28
#846277
GPz wiring diagram.  There are a couple of manuals floating around the internet that cover the KZ1000/KZ1100/ZX1100 models & both pdfs may be linked here on KZR.  One covers the 81-83 KZ1000/1100 models & I believe it serves as the base manual for the 83-85 manual.  One of the pdfs should have a wiring diagram for your GPz.
ZN700-A1 (USA) & ZN750-A1 (CN) Wiring Diagram.
If it doesn't appear big enough click it a couple of times. or open image in new window, then click to enlarge.
Last edit: 06 Apr 2021 13:28 by martin_csr.
  • slayer61
06 Apr 2021 14:05
#846281
Thanks Martin! You are the MAN!
Is this from your personal stash? Where did you find it? I have a (pretty good) copy of the GPz, but had no luck finding the ZN one.
  • martin_csr
06 Apr 2021 19:26 - 07 Apr 2021 06:08
#846307
I got if from someone on another forum several years ago.  I wasn't sure if the 700 Ltd Shaft meter wiring would be the same as the ZN1100.
Last edit: 07 Apr 2021 06:08 by martin_csr.
