Eletrical connections (building new harness)
  • gordone
  • gordone's Avatar Topic Author
23 Mar 2021 22:48
#845418
Good day,
I`m planning for building new eletrical harness by using motogadget m-unit, hope you think that is not a bad choice?
What I`m looking for is quality eletrical connections (joing cabels) and also cabels every material I need to build these, what do you recommend?
Quality connections who will work for long time....
Don`t know if the word connections is correct to use in English?
Project:
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Eletrical connections (building new harness)
23 Mar 2021 23:30
#845419
I prefer to use Deutsch connectors if it is not a restoration.
This website has helped me.
www.rbracing-rsr.com/wiring_ecu.html
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: TexasKZ, Mc Tavish
  • gordone
24 Mar 2021 01:05
#845420
Thank you !
Its for my hobby project, not a orginal restoration.
These looks really PRO :) hehe how easy is to make the connectors ?
I have started thinking I must start first to make a connection drawing diagram, so I can see what type of connectors I need (numbers of cabels)... and then order... ?
Do I need special tools for using these connectors ?
Project:
  • TexasKZ
  • TexasKZ's Avatar
24 Mar 2021 04:20
#845421
Wow! There is a lot of information on that website.
  • F64
  • F64's Avatar
  • 81-KZ440D2
24 Mar 2021 12:09 - 25 Mar 2021 12:11
#845454
www.elfadistrelec.no/en/manufacturer/deu...an_ted?no-cache=true
no.mouser.com/TE-Connectivity/Connectors...word=deutsch&FS=True
You will need a crimping tool for Deutsch connectors.
The crimping tools can be more than $200 USD.
There are crimpers that sell for $40 USD.
You need the correct size crimper.
prowireusa.com/c-14-tools.html?p=3
Yep Texas.
They have a ton of info on that website.
I've been referencing their page for years.
Oh, and a wire calculator to figure out wire size.
www.wirebarn.com/Wire-Calculator-_ep_41.html
81-KZ440-D2.
LIC, NY
Last edit: 25 Mar 2021 12:11 by F64.
  • Nessism
  • Nessism's Avatar
24 Mar 2021 14:39
#845462
Vintage Connectors has lots of good stuff for building a harness.  Check out the terminal pliers which roll over the tangs on the brass terminals, just like OEM.  Good stuff.
vintageconnections.com/
  • Mikaw
  • Mikaw's Avatar
24 Mar 2021 17:37
#845468
I have had great success with material from Vintage Connections. I purchased their barrel terminal crimp tool. I’d suggest getting a few extra terminals to practice with. The crimp tool works great if operated correctly. Lol
