Left and right handlebar switches
  • gordone
  • gordone's Avatar Topic Author
20 Mar 2021 11:30
#845272
I’m consider make new harness include switches.
Do you have recommendation for left and right handlebar switches, quality parts?
Project:
  • gordone
Re: Left and right handlebar switches
22 Mar 2021 03:44 - 22 Mar 2021 04:28
#845336
Project:
Last edit: 22 Mar 2021 04:28 by gordone.
  • TheTrout
  • TheTrout's Avatar
22 Mar 2021 04:31 - 22 Mar 2021 04:33
#845337
I had to replace the right side switch and used one that looks just like that.  I seem to recall the wires not being an exact match and having to figure which were the correct wires to use.  It wasn't hard, but just took a little figuring out.  That was on a 78 KZ1000.  The replacement has been just fine and looks factory stock.
1978 KZ1000B2
Last edit: 22 Mar 2021 04:33 by TheTrout.
  • gordone
22 Mar 2021 05:55
#845341
Thank you.
Wiring will be done all over so that is not a issue, had more question to the quality.
Project:
  • martin_csr
  • martin_csr's Avatar
22 Mar 2021 06:39
#845343
Just an FYI. Those are Emgo brand handlebar controls. Probably made in Taiwan which is a good thing (not china).
The Emgo part numbers are 34-68891 & 34-68892. see pg. 298 in the 2019 General catalog.
www.emgo.com/index.php/catalogs
www.emgo.com/images/pdf/2019general.pdf
