KZ200 High Beam Indicator Lamp
  • Robert
  • Robert's Avatar Topic Author
16 Mar 2021 16:14
#845025
My highbeams indicator lamp is constantly on. The switch changes the beams like it should but the highbeam indicator lamp is on no matter which being selected.
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: KZ200 High Beam Indicator Lamp
16 Mar 2021 20:07 - 16 Mar 2021 20:07
#845038
On the surface, it appears your hi beam indicator is wired to a constant key-on 12v source right now.
One wire going to the high beam indicator may be black/yellow which is ground.
The other wire SHOULD be the same as your high beam +12v wire. They are spliced together.
Trace the wire. They should be the same wire.
Either that or you have a short somewhere.
This is a best guess as I can't find the schematic for your bike.
81-KZ440-D2.
LIC, NY
Last edit: 16 Mar 2021 20:07 by F64.
The following user(s) said Thank You: Robert
  • martin_csr
  • martin_csr's Avatar
17 Mar 2021 06:52 - 17 Mar 2021 06:52
#845058
KZ200-A1 wiring diagram.
Last edit: 17 Mar 2021 06:52 by martin_csr.
The following user(s) said Thank You: F64, Robert
  • F64
  • F64's Avatar
  • 81-KZ440D2
17 Mar 2021 08:15 - 17 Mar 2021 10:29
#845065
Thanks Martin..
Yeah, the red/black wire should be going to both your high beam and your high beam indicator. The only indicator lamp in that area that should have full time +12V is your neutral light. What turns on the neutral light is a switched ground wire.
Your high beam indicator has a full time ground wire and what turns it on and off is a switched +12V wire(red/black)
81-KZ440-D2.
LIC, NY
Last edit: 17 Mar 2021 10:29 by F64.
  • Robert
30 Mar 2021 04:43
#845792
Found the problem. I had the highbeam and low beam bulb leads crossed inside the headlight housing. Recently, I fabricated an H4  headlight bulb into the stock sealed beam housing and when I went to connect leads, I had a high and low beam wires crossed. I do not understand why that would cause the highbeam lamp to stay on but the problem is now solved. Thanks.
